Bushnell trkr h150l. main wht. spot blinks once with every press of "on" button. Red and blood lights functions are good.
    Top Expert:
  • Televison & ... Master
  • 75,157 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 16, 2016
What will make my light dim Bushnell trkr 500
Hi,if the light dims its normaly a signe that there is a fault on the charging system,check battery,stater,rectefier.
Jan 04, 2016 | Bushnell Optics
What is the tv code for the 40 inch dynex tv?
The code 135 should work. If not, try the code search function:
  1. Turn on the device that you want to set.
  2. Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
  3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the LED light will blink once and then remain solid red.
  4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note: LED will blink once each time you press ON/OFF button)
  5. Once this occurs, press ENTER button to store the code and the LED light will turn off.
Aug 03, 2011 | Innovage Jumbo Remote Control
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
Need help with the codes for a innovage jumbo universal remote . instruction for T.V. brand name symphonic
Well First, make sure the device you want to connect with your remote is turned on, whether thats the television. Now aim the Innovage remote at the device. Press the button on the remote control that corresponds to the TV. Now, press and hold the SET button on the remote control until the LED light on the remote control holds a steady red.
Enter the 4-digit code for your device by pressing the number keys on the remote control (see list below). When you press the fourth digit, the LED light should turn off. This means the remote and the device are "speaking" to each other. Press the OK button to store the code.
If the LED light blinks three times and then remains a solid red, the Innovage remote doesn’t recognize the code for your device. Verify the correct code, then go through the programming steps again.
Test the function by using your remote to cycle through all programmed TV.
Turn on the device you wish to match with your remote. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red. Press the button on the remote for the item you want to program TV. The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program turns off. The LED light will blink once each time you depress the On/Off button. When the device you want to program turns off, press the ENTER button. The LED button will turn off and the code for that device will be stored in your remote.
Good Luck!!
Thanks
Jan 16, 2010 | Televison & Video
I do not know the code to my Innovage television remote.
If you do not know the code for your remote or have the manual handy, I recommend using the auto-search function.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 21, 2009 | Innovage Jumbo Remote Control
Remote code
You might consider the auto-search function.
  1. Turn on your TV.
I hope that helps.
Oct 05, 2009 | Innovage Jumbo Remote Control
I need the codes for myInnovage Jumbo remote
To find the codes to program your dvd into the Innovage Jumbo Remote, you can look your brand of DVD up in a list, or you can use the automatic Code Search function.
Here are the Code Search instructions:
  1. Turn on your DVD.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the DVD button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the DVD turns off. The LED will blink once each time you press ON/OFF.
  5. Once the DVD turns off, press the ENTER button to store the code. The LED light will turn off and your remote control is now programmed for that DVD player.
Hope that helps.
Oct 03, 2009 | Innovage Jumbo Remote Control
I need a code for my universal remote i have a sansui tv
I recommend using the auto-search function of your remote.
  1. Turn on your TV.
I hope that helps.
Jul 11, 2009 | Innovage Jumbo Remote Control
I need the code for my innovage jumbo remote
I recommend using the autosearch function of your remote.
  1. Turn on your TV.
I hope that helps.
Mar 30, 2009 | Universal Remote Control 6-Device...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
