Question about Sony Televison & Video
Changed my t-con board on my sony kdl 40v-4100. An it worked for 2 mins than the screen went blue an no picture. But have sound. An it's a new t-con board. Also put the old one back in am same thing.
  • yadayada
    yadayada Dec 16, 2016
    Give it up and replace the TV
  • 643 Answers
SOURCE: I have a 40
panel is bad. usually not economical to repair. cost for panel around 750 plus your labor.
Posted on Jun 04, 2009
  • 148 Answers
SOURCE: 2 years old Sony Bravia KDL-52W3000 flat screen- I
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! ..Here is a picture of what you are looking for inside the tv...I hope this helped, if it did (or not)please rate, thank you!9441f5a.jpg
Posted on Feb 03, 2010
  • 49 Answers
SOURCE: sony 46 KDL 46S2000 screen went black and the
you can referen the article:
How to Fix a Black Screen at Startup
maybe it can give your some help
Posted on Mar 05, 2010
  • 1779 Answers
The part # you gave is the Control Board which sells for $668.79. The T-Con board your looking for is part of the LCD Display Panel and is not sold separately. I suggest you start by cleaning the ribbon cables from the control board to the t-con board. If that doesn't help then you had better take it in to a service center to verify which part is bad because there are no refunds, only replacement after you buy a board.
Posted on Nov 19, 2010
SOURCE: sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
Posted on May 11, 2012
Sony 52 inch bravia picture went dark
Hate to give you some bad news...But most likely you have a defective screen. You may be lucky and just have a bad T-con board. Which will do the same thing. But, this is a slim chance of it being the issue. As I have had many of these with bad screens. And only 2 were the T-con board which the color was off and pict was darker than normal. It is the board at the top center of the TV.
Apr 24, 2014 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony 40 inch Bravia screen has sound, but picture have weird lines that go across screen
It could be caused by a bad T-Con board or defective LCD panel. The panel is more expensive than the TV, so hope that it is the T-Con board. Below is a parts list for your TV model.
Nov 03, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
We are having issues with the screen. The display of our Sony Bravia KDL-40V4150 shows straight vertical lines all the way across the screen. How do we fix this issue?
Sounds like a defective T-Con board, but it is better to test it before replacement. Also there is a possibility to repair it at a lower price. You can find a company that is testing this kind of T-Con boards and repair them here:
Sep 17, 2013 | Sony Bravia KDL-40V4150 40 in. LCD HDTV
Sony Bravia Kdl-52VL150 has vertical lines on screen. Is this fixable and how.
usually that symptoms cause of faulty t-con board..
but before you do that kindly play dvd on your tv and look at the picture if still persisted just change the t-con board to works fine again
Jul 18, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony Bravia KDL-46S4100, No Picture No sound
I have a sony bravia kdl 40v 5100 for less than two years and i did not purchased an extended warranty and now my tv is down.
I have no picture, no sound just a black screen when i turn the power on, the power (green) light is lite up and the tv turns off by itself for like less than 30 seconds. I have tried to press as many buttons on the remote control and on the side of the TV to get any message but nothing seem to happen. Any suggestions and solutions? Thanks
Aug 23, 2011 | Sony KDL-46S4100 46 in. LCD TV
My Sony Bravia KDL-52W3000 when turned on after being off for a while has a weird double/distorted picture for about 15min. then it clears up and has a perfect picture for the rest of the time you watch...
Take care.....
Aug 04, 2011 | Sony BRAVIA KDL-46V3000 Television
We have a Sony Bravia KDL 52 xbr9 tv. It is about 1 1/2 years old. We bought it Nov 29, 2009. For the last few weeks when we turn the TV on, the picture is distorted and dark (there are horizontal...
The board that call the T-CON board it is dying and dead soon.That why it is causing horizontal or vertical lines and distoted pictures.This T-CON board sit in at the bottom in the middle of the tv LCD screen panel and it only job are to decoded pictures pixels before it go onto the tv LCD screen panel.Tries websites, to buy a whole new refurbish T-CON board for the replacement.
Jul 20, 2011 | Sony KDL-52XBR9 52 in. LCD HDTV
I have a 40inch Sony Bravia and all of a sudden I have 4 pin stripe lines on the left side of the screen 2 red 2 blue
This tv have a dead board call the T-CON decoders board.This board sit right at the bottom at the middle of the LCD screen panel.Tries websites like, to buy a refurbish T-CON decoders board for the replacement.
Oct 21, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No picture or menu, bypassed cable box, same
Backlight failure. Need new inverter board or panel
Dec 15, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Open Questions:
Televison & Video Logo
26 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
