Question about Car Audio & Video
2004 Mercury Sable LS. 6 Disc changer. When starting the car, the changer starts with disc 1, track 1 every time rather than picking up where it left off before power off. Is this normal?
    Top Expert:
  • Car Audio & ... Master
  • 52,135 Answers
Of course it is normal .
Posted on Dec 16, 2016
  • 3 Answers
SOURCE: blaupunkt ATLANTA SQR 49 and cd changer cdc-m1
Try a cleaning disc in it
Posted on Aug 21, 2007
SOURCE: 6 disc cd changer skipping
Laser is loose or out of alignment return to factory for adjustment.RICHARDM69
Posted on Dec 15, 2008
SOURCE: changer does not work
Had the same problem!! Found the solution here under "Wont Play" question. Push that cd chngr magazine (holder) all the way into the unit and tap with a blunt object( Dont tap too hard,it's plastic!!) screw driver worked for me! Push the eject button and you'll hear the unit working! Pop it in and out and it seemed to unfreeze whatever was frozen!! It finally loaded a cd and started playing again. I checked all 6 and they were okay!!
Thanks support guys for your help!!
I'm now a member!!
Posted on Jan 16, 2009
str8gooods
  • 13 Answers
SOURCE: I removed my Mercedes 6 disc cd changer from my
Without power. you may just have to disassemble the unit.
Posted on Mar 08, 2010
SOURCE: sony cdx-t69 CD Changer Unit
Bought a toyota with sony cd changer and had magazine stuck. Disconnected the cables at the back and left for 5 min. Hooked it back up switched to acc and pressed the eject button and came straight out. Didnt need to reset radio and retune.Now works fine.
Posted on Jul 01, 2010
Skips when playing disc, may go from track one to track ten for no reason.
It sounds like you have the cd on random or shuffle. Look to see if you have a button marked rdm or shuf or some variation of that. If so, try pressing that button to see if random/shuffle turns off.
Mar 05, 2013 | Pioneer 1990-1992 Lexus Ls400 86270-50010...
6 disc cd changer jammed in 2004 mercury mountaineer, says error when i try to eject or play jammed discs.
personally I used another not so valuable CD to push the jammed CD back, it appears the ejected CD may bump the open exit gate and get stalled. It has happened several times. Good luck
Mar 15, 2011 | 2004 Mercury Mountaineer
My Honda accord Sedan car CD Player cannot eject CD .
Before connecting any cables you must set the dip switch box to the position listed for your vehicle. If you set the dip-switches after you have connected cables to the box, you must disconnect and reconnect them for the changer to operate. All 1992-2004 Honda's are compatible with the Neo Changer except the 2003 and 2004 Honda Accord and all Honda Element vehicles. Some radio models require pressing "Seek >" once to start playing after changing CD or after startup. The radios display will not show the proper disc number after disc six. You can use all 10 discs in the magazine, but the readout will be wrong. This is not a technical problem; the car stereo was designed for no more than six discs. *Due to the direct access disc system, you will not be able to directly access discs 7-10. To access these discs you will have to go to the last track on disc 6 and let it play until it loads disc #7. ( you can fast forward the track, but you must let it play the last 5 seconds of the track, for it to change to disc # 7 Switch to the Neo Changer by pressing the "CD" button. To change discs press "Disc -" and "Disc +" To change tracks simply press "Seek <" or "Seek >" S E T T I N G S F O R H O N D A 1 2 3 4 5 6 7 8 ON OFF OFF ON OFF OFF ON OFF
Dec 21, 2010 | 2000 Honda Accord
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
I have a 2005 Malibu with a 6 disc cd changer, I know the changer has 5 of the 6 disc inside it. A while back it started clicking. I removed the fuse and left it out because there was a smell like and I...
There may, or, may not be a small pinhole in the front panel of the changer. If it does have this hole, take a paper clip and insert it straight into the hole and this will enable manual ejection of the disk tray. If the hole is not there than the housing has to be removed to gain acess to the disks. Thank you, Dana
Feb 14, 2010 | 2005 Chevrolet Malibu
2002 infiniti i35 cd 6 changer
The 6 cd changer should be located in the trunk eith on the right or left side. I hopre this helps you. Don't forget to rate my answer.
Feb 12, 2009 | 2004 Infiniti I35
Cd changer is reading cd's as BAD
check the conection interface for bad contact.
May 04, 2008 | Car Audio & Video
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
