Honeywell wireless thermostat is stuck in wireless set up mode. i get error code e1 38, connected light not flashing on eid. I Pressing button on eid does nothing. Please help i cant control settings
  • Brad Brown Dec 16, 2016
    Hi Georgius O Dalaigh, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what model and make
2 Suggested Answers
DIESELMUDDER
  • 2760 Answers
SOURCE: honeywell th6320r1004 thermostat is stuck in connect wireless mode. Eig unit not reading thermostat and fan is stuck on. Cant exit set up wireless mode and hard reset wont work. Help please?
How exactly did u preform the hard reset ??? U do know that u need to remove both the batteries and remove power to your heater (its connected too) for like one minute or more to properly preform a hard reset >
Posted on Dec 16, 2016
Honeywell th6320r1004 thermostat is stuck in connect wireless mode. Eig unit not reading thermostat and fan is stuck on. Cant exit set up wireless mode and hard reset wont work. Help please?
Dec 16, 2016 | Heating & Cooling
I have an opener stuck in vacation mode... the wall unit is one button, the remote is 3, but we bought this house and there are no markings on the buttons. How do I get it out of vacation mode?
Enter the existing Code and press * key. The light should flash twice. If the light does not flash twice you have the wrong code. Now enter the new code you want to use and press Enter. You should now be set to use the smart learn button on the back of your receiver.
Jan 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
I JUST INSTALLED HONEYWELL TH6110D1021 THERMOSTAT FOR A STEAM ZONE VALVE. I SET THE THERMOSTAT FUNCTION BY PRESSING THE UP ARROW AND FAN BUTTON. THEN CHANGING THE RIGHT NUMBER TO 2. NOW I WANT TO CHANGE...
Hi and welcome to FixYa. I am Kelly.
Suprizingly enough there is an abundance of manuals for your Honeywell Programmable Thermostat. Use this link and at the bottom of the page you can download any of the manuals.
http://customer.honeywell.com/Honeywell/ProductInfo.aspx/TH6110D1021
Just note that pop ups must be enabled to download the manuals
Printable Quick Reference Sheet (after download)
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1778ES.pdf
Thanks for choosing FixYa,
Kellly
Oct 15, 2010 | Honeywell Programmable Thermostat Heater
Honeywell CM921 Showing room temp at -24 degrees, How do I reset?
Heya this is a manufacturing fault from honeywell them selves when it comes up -24 basically it needs to be replaced there is no way around in if you get in touch with honeywell they are generally good about it also if you provide them with the date code and model code they will be greatfull as it seems they have sent out a "bad batch". you locate this by:
A) Move the slide in to the off position
B) Press and hold i for 5 seconds
C) Unit will enter settings mode
D) Press and hold the i button and the + and ¿ button together
E) The unit will hold the relay on for 5 minutes and you can view by pressing the down arrow twice for model id/date code (ww/yy)
I hope this helps
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
Honeywell VisionPro USER SETUP CODES OR INSTALLER CODE FOR TEMP RESTRICTION
You need to get into the installer setup. Download the installer manual from Honeywell or an on-line vendor and it has the installer codes to alter the maximum heat setting. Press the system button and then buttons 2 & 4 at the same time for 5 sec to enter the installer mode. I believe the code is 0600 and then you enter the max temp for heat setting. Press done and your done!. Try this link for the installers manual http://www.alpinehomeair.com/related/Honeywell_VisionPro_8000_%20Install_%20Instructions.pdf
Jan 21, 2008 | Honeywell Programmable Thermostat Heater
Honeywell thermostat RTH230B
Sound like you need new one... take a look on amazon ecobee3 Smarter Wi Fi Thermostat Remote Sensor. It's not worth repairing it..
Jan 06, 2008 | Honeywell Programmable Thermostat Heater
Error code e-3
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Oct 02, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Heating & Cooling Logo
175 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
