Question about Frigidaire FMV156DC Microwave Oven
Mounting bolts firgidaire FMV156DC
I lost 1 of these bolts that mount the unit to the upper cabinet when I renovated my kitchen. Is there a way around buying the whole kit for $50-$60 dollars?
    President:
  • 1,273 Answers
Where I live there is a bolt shop....really. If you can, find such a shop, and take your other bolt with you and 'match 'em up'.
Another possibility is that Lowe's carries speciality bolts. They're in cabinets/drawers in the hardware section, not hanging on the wall. H/Depot probably has a similar arrangement.
Yet another possibility (and I think it's your best shot) is that, if you can match just the threads, you can buy a piece of all-thread (it's just a piece of steel rod, with the threads running the full length of the rod). Thread your nut onto the all-thread just past where you are going to make your cut, and cut with a hack saw. (You run the nut down on the rod so that, after you make your cut, you unscrew the nut over your fresh cut to straighten out the threads deformed by cutting). Total cost for all-thread and nuts......around $5. Use your existing bolt as a pattern for the new bolt, and leave evough extra to accomidate the nut that you'll add in place of the head of the old bolt. Anyone working in any hardware department anywhere on the planet worth their salt can help you.
Best regards, --W/D--
Posted on Jul 20, 2009
Diagram of relay switches for firgidaire microwave
Hello friend, thank you for your inquiry!
I see your question is labeled under the model number FMV156DC. Per that model I have located the wiring diagram. I hope this information has been helpful. -Matt
Frigidaire Manual Search Results
Oct 10, 2014 | Frigidaire FMV156DC Microwave Oven
LG LMV1680ST no upper mounting
Look for back mounting bolts location, find your wall studs location and mount from the back
Apr 23, 2012 | LG LMV1680ST Microwave Oven
What size bolts do i need in order to mount it under the cabinet. the bolt that comes from the cabinet into the micro
mcdevito75 here, Best Bet bring the mounting bracket and bolts recieved with the unit to your local hardware store. they will give you the correct bolts need to mount undera cabinet.
Jun 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
I can't find bolts or screws that hold the unit in place. I need to remove the microwave in order to install new one.
HI there,
Here's HOW;
  1. Remove the face plate above the door.
  2. There were 2 bolts in which you will need a screw driver to loosen it
  3. This bolts go all the way to the back of the microwave.
  4. You still need to remove the one - three screws that's above of the cabinet. You may have to jar it loose if it still stuck.
Hope this helps.
Let me know for further instructions.
Aug 04, 2009 | Microwave Ovens
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
One stud in the middle for an OTR Microwave Install?
i had the same trouble, yes i used a solid bolt to hold the microwave bracket in the stud then used the biggest toggle bolts that will fit, also the cabinet will not have to be changed. it works fine, if you had a vent a hood dont forget to hook up the exhaust vent. i figure your old exhaust vent is in the cabinet like mine was
Dec 31, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Jul 01, 2008 | Microwave Ovens
How can I install this oven GH9115XE?
You may be looking for this flat head 1/4 x 28 threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded holes in the top of the microwave:
GE # WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites)
or a set of three
GE # WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites)
Jan 21, 2008 | Whirlpool GH9115XE 850 Watts Convection /...
Frigidaire FMV156DC Microwave Oven Logo
94 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
