Question about Toro Garden
Toro 418ez won't start.I left a wee bit of gas in it last year. Just a few drops. What do I need to do to start it?
    Champion:
  • 223 Answers
Clean the carb and flush the old fuel.
Posted on Jan 03, 2017
Motor mower wont start
By tipping a 4 cycle motor on a lawn mower or any equipment, you have all the oil and gas running into the combustion chamber and sometimes the oil and WATER will get into the tank. It will need too have the spark plug removed, the engine turned over with the starter to blow the oill, gas, and water out of the cylinder(s), the plug should be either dried and gap reset, and the gas tank drained and FRESH gas put in it. Replace the spark plug prime with just a few drops of gasoline in the carburetor throat and restart and let run to dry evrything. NOTE: An oil change is recommended, too!!
Jan 14, 2014 | Garden
My 418 ZE Toro snowblower won't start either manually or electrically. I need to empty the gas. How do I do that?
Easiest way is to pull the fuel line from the carburetor.
If you have not started it since last year and had the gas sitting in there. You need to clean the carburetor too.
Ethanol Gas ruins Carburetors on all engines. Tell your congressman to stop this Ethanol gas madness
Dec 15, 2013 | Toro Garden
Toro recycler lawn mower
if old gas was left in the engine a good carb cleaning will need to be done
May 11, 2012 | Toro Power Lawn Mower
Toro snowblower wont start. seems like the fuel isnt getting into carb.how and what can i do
Reference your toro snow blower. does it start and run for a few swconds then die. if so It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now.
Oct 21, 2011 | Toro Lawn Mower With Toro Power Tools
Toro GTS 20332 (bought it 12 months ago) won't run
I believe that Toro Guarantees to start 1 Pull, was gas left in it all winter?, If so this is'nt covered under warranty, cause gas is to be ran out or dumped out at end of season this will prevent any gumming up of carb . did you completely disassemble carb? does it have a primer on it, those gskts need replacing, clean out the jet in bottum of float bowl,small holes,sometimes missed and remove and check your needle/seat to make sure that when float drops gas runs out then lift float up and gas should stop. hope this helped you,another thing spray carb cleaner in carb and pull over and see if it will start that way enough to keep running with choke to see if it will **** gas into it
May 16, 2011 | Toro Garden
LEFT GAS IN SINCE LAST YEAR TORO CCR POWERLITE NO GAS COMES OUT WHEN I TURN IT UPSIDE DOWN
Sounds to me that it leaked out.you might want to check the fuel line for leaks.
Dec 28, 2010 | Toro Lawn Mower With Toro Power Tools
I have a Toro 20332 that stopped running after 20 minutes and would not restart. Tried several days later and it would start for a few seconds and stop again. Took it to the Tor dealer twice last year...
Just take off your carb and give it a good cleaning. Be careful and watch how everything comes apart so you can put it back together with little or no trouble.
Jun 07, 2010 | Toro Lawn Mower With Toro Power Tools
Toro lawnmower appears flooded and won't start.
Actually all you have to do is take out the spark plug and pull the engine through several times. What has happened is the intake valve was open when you tipped the motor so when the fuel ran out of the carb into the engine it saturated the spark plug. You may have to by another spark plug to get it started or dry yours out very well. The main thing is to make sure that most of the liquid gas has exited the cylinder.
One more thing.... the float needle may have tilted a bit in the seat as a result of haging it tipped on its side. This is going to sound a bit strange BUT... grasp the handle and alternately bang the front and rear wheels on the ground a couple of times by lifting the back of the mower with the handle about 2 inches and drop it. Do the same by pressing down on the handle for the front tires. (2 inches and drop)
IT WORKS!
This should get you going. IF not just respond here and we can continue troubleshooting.
Kelly
Apr 13, 2010 | Toro Lawn Mower With Toro Power Tools
Garden Logo
97 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
