Boot fail when i turn on - Computers & Internet
    Top Expert:
  • 4,740 Answers
You may have to go into boot up in safe mode.
goto this link and read about how to boot up in safe mode.
How to Use Safe Mode to Fix Your Windows PC and When You Should
Posted on Dec 16, 2016
When I turn on the PC the following message appears and my system goes turn off... For Realtek RTL8101E/8102E PCI-E Ethernet Controller v2.13 PXE-E61: Media test failure, check cable PXE-M0F: Exiting...
This error occurs when the BIOS finds no hard disk drive to boot from, and tries and fails at booting thru the network jack (PXE Boot is a network boot used in large corporations, usually to image a system.)
Reseat the hard disk drive in the system, then reset the bios defaults and see if the system will boot normally. You can also try running diagnostics (Fn + Power on a Dell)
Most likely scenario is that the hard disk drive has failed and you will need to replace it.
Jul 15, 2011 | Computers & Internet
PXE-E61 : MEDIA TEST FAILURE , CHECK CABLE
Normally, your laptop should be configured to boot up from the hard drive before trying the network boot up. When the hard drive fails or is no longer available, or the boot up sequence in BIOS Setup has been changed so that the network boot is set before the hard drive, the symptom you describe fails.
I would recommend that you do the following:
1. Check BIOS Setup & make sure the boot sequence is set in the correct order (Hard Drive 0 should be before Network Boot).
2. Make sure that the hard drive is seated properly in its slot & that all connections are tight.
3. Make sure that the hard drive powers up when you turn on the laptop.
If none of this helps, then your hard drive has failed & might need to be replaced.
Mar 09, 2011 | Compaq Presario 700 470024-192 Notebook
Pxe-e61: media test failure check cable pxe-m0p:exiting broadcom pxe rom operating system not found
If none of this helps, then your hard drive has failed.
Mar 08, 2011 | Gateway MT3705 Notebook
When I turn the computer on, I get the following message: PXE-E61 media test failure, check cable PXE-M0F exiting intel boot agent Reboot and select proper boot device or insert boot media in selected...
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Nov 26, 2010 | Gateway 510 X (10272197) PC Desktop
Mouse freeze up when i first turn on cp
try to boot in safe mode and check if still freezes. if yes then. boot to f8 select last known good configuration. if fails.try to do system restore using the recovery disc. if fails then before reinstalling OS. try to connect an external mouse first then update antivirus then run a full system scan. if still fails then reinstall. OS.
Oct 24, 2009 | Dell Inspiron 1545 Notebook
I have a message that says , error message: PXE Media test failure chek cable
PXE or Pixie errors occur when the system tried to boot to the network connection and failed. This error usually occurs when the hard drive fails. If your system does boot to windows and you are just getting the error, then you can change the network card setting in BIOS to turn PXE boot off.
If the error occurs and the system doesn't boot to the hard drive, then the hard drive has most likely failed.
Sep 30, 2009 | Compaq Armada E500 Notebook
Fail to boot
When you say boot do you mean POST?
Is it turning on at all?
What happens exactly when you press the power button?
Any beeps?
Open the case and remove everything except 1 RAM chip, the cpu, the cpu cooler. Hook up the monitor to the onboard graphics and try to boot again.
If it POSTs then you know that you have a problem with one of the pieces of hardware you removed, replace them 1 at a time until it fails to POST then you know which piece is defective.
If it still doesn't POST with everything removed, try a different RAM chip, if it still fails POST then you need to replace the motherboard.
Sep 16, 2009 | Intel DG965RY Motherboard
Lowrance 330c screen says '' boot failed''
Try a hard reset:
1. Turn the LMS-330 off
2. Press and hold the ZIN, ZOUT, and PWR buttons
3. Release the three buttons once you see the "warning, do not rely..." message appear
If you get that far, the problem is solved. If you get boot failed again, try installing the latest update which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If you still get boot failed, you will need to get the LMS-330 repaired/replaced. You can contact Lowrance support at 800-324-1356 or email them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
Mar 22, 2009 | Lowrance LMS-330C GPS Receiver
Fails to boot
You might try a Hirens Boot CD, un-zip the files, create a bootable cd from the .ISO file and boot your troubled system, select virus scan on boot.
Apr 16, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
