Question about Watches
How do i get battery case out - Watches
How to replace the battery of a emporio armani ar0106
Do you have a photo of the watch case back? It's either going to unscrew in which case you may need a special took, or it might be a snap-back case in which case it can be pried off.
With the case back off, its best to use a magnifying glass or eye loupe to look closely and determine how the battery is held in place. It's usually not to difficult to discern how to remove it (if you send me the movement number I can guide more specifically. It's important to replace it with the same battery and it will be numbered for identification.
Dec 06, 2014 | Watches
How do you take the back of a wrist watch off so you can change the battery
The Proper way is with a "watch case wrench". They can be purchased for a few dollars on Amazon and E-bay. In most cases unless you are changing many watch batteries the best option is to call around to local jewelers and pawn shops and ask how much to replace a watch battery. In my town it ranges from $30 to as little as $5.99 battery included.
Dec 14, 2013 | Meco 2PCS Watch Case Back Opening Tool...
How to change battery on a swatch skin watch
  1. Place the watch in case holder. Place the watch in the case holder, if you have one. If you do not, place it on a soft cloth.
  2. Check for room to work. Check to see if there is room to attach the adjustable case wrench and rotate it 360 degrees. If not remove watch band.
  3. Remove case back. Fit the adjustable case wrench into the slots on the case back. Tighten it down until it is snug. Be careful not to slip with this tool as it can scratch the case back of your watch. Work slowly. When it is unscrewed gently pry up the case back taking great care not to damage the internal gasket. If the gasket gets damaged it will need to be replaced with the battery to retain water resistance.
  4. Remove battery. The battery will be held in place by some type of retention device. It will need to be removed. Some clips will be removed by using tweezers. Some clips may be moved using a screw driver, and some simply bend out of the way slightly. Remember how it was removed as it must be put back in place exactly for the circuit to be completed after battery change. If the clip is removed, place it and any screws in a paper cup to prevent loss. Remember how the battery was seated, plus (positive) side up or down etc. it needs to be replaced correctly to work.
  5. Test battery. Using the battery tester check the battery. If it is dead move to next step, if it is not take the watch to a jewelers for inspection.
  6. Clean and inspect battery box. Inspect the battery box the battery came out of. If there is corrosion take it to jewelers for inspection. If there is light dust it may be cleaned with a clean soft cloth.
  7. Buy battery. Use the numbers on the battery and buy a new one. Occasionally the number will be obsolete and you will be referenced to a replacement battery in the battery charts. This is the time to also replace the gasket if you need to. Check with a watch maker or jeweler, or the watch company to buy a replacement. We cannot stress enough how important this gasket is to a water resistant watch, without its integrity your fine watch may no longer be resistant.
  8. Replace battery. Using the plastic tweezers if you have them, or fingers wearing cotton gloves, replace the battery. Never use bare fingers as finger oils may corrode or short out the new battery. Carefully replace the retention device as it was remove.
  9. Replace case back. Make sure that the gasket is in place, and not pinched or caught in the case back when you set it in place. Screw down the case back using your fingers until it is tight and needs the case wrench. Attach case wrench as before and tighten down the case back.
  10. Reset and clean watch. Using the appropriate method reset the watch. Use the polishing cloth to clean off any dirt and finger prints.
OR...take to your local jeweler/watchmaker who has the appropiate tools and let them do it for you!!!! :)
Aug 14, 2010 | Swatch Skin SFK254 Watch
How to replace a battery on a ebel watch?
The most water resistant watches will have a screwed down case back and crown for maximum water resistance, both of which are backed by internal gaskets. These are the types this articlde will concentrate on. To change the battery in a water resistant watch you will need:
  • Adjustable case tool
  • Case holder ' + google_ads[0].line1 + '
    ' + google_ads[0].line2 + ' ' + google_ads[0].line3 + '
    ' + google_ads[0].visible_url + '' + ' Ads by Google'; } else if (google_ads.length > 1) { s += 'Ads by Google
    '; for(i = 0; i ' + google_ads[i].line1 + '
    ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + google_ads[i].visible_url + '
    '; } s += ''; } document.write(s); return; } google_ad_client = 'pub-8735055091446807'; google_ad_channel = '5953492595'; google_ad_output = 'js'; google_max_num_ads = '2'; google_ad_type = 'text_html'; //google_image_size = '468x55'; google_feedback = 'off'; // --> google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
  • Small screw driver
  • Polishing cloth
  • Cotton gloves
  • Small tweezers
  • Plastic tweezers
  • Soft clean cloths
  • Battery tester
  • Paper cup
Aug 10, 2010 | Ebel Sportwave Gent 100m Water Resistant...
Is it possible to change the battery on the Technomarine 10900 at home (with the proper tools) or do I need to get it to a repair centre?
It is possible. Open the watch case back, memorize all the writings on watch battery as well as how the battery is positioned (+ and -). Buy exactly the same battery, replace it and close the case back. To be sure case back is closed as tight as it was, draw fine line across the case and case back with non-permanent marker. This will help you align when closing the watch and you can clean it off later. Rate me, please.
Apr 26, 2010 | TechnoMarine RSQC11 Wrist Watch
HOW TO CHANGE BATTERY ON AN OAKLEY BULLET WATCH
Open the watch case back, release the upper contact (unclip or unscrew it), memorize the writings on battery and the way the battery was placed in. Buy exactly the same battery, insert the same way in and close watch case back. Reset the watch and you are done. Some watches need a shortcut to be made before resetting. This should be written on the label covering the battery. Rate me, plz.
Mar 15, 2010 | Oakley 4 D Bullet Watch Titanium Case with...
How do you change the battery on the T-Touch Expert watch?
I would not recommend changing this battery yourself unless you have the proper tools to close the case! If its a screw back then you will need a case wrench to close it otherwise you will scratch the case and case back! Plus it has a touch sensitive crystal! Screw that up and you will have to send it back to Tissot to have it repaired! That will NOT be covered by the warranty!
Jan 09, 2010 | Watches
Timex expedition compass battery replacement?
hi
i am not an expert in this particular case but i followed theses below steps . here are they.....
Unscrew the case back with a case back tool (aka Jaxa wrench) which engages
the notches in the case back. I'm assuming the watch has a screw back - if
it has notches it does. Pop out the old battery.
In some watches you have to
unscrew a clip but in most the battery pops right out. Examine movement for
evidence of battery leakage or other damage. Carefully clear away any crud
at the edge of the case - the tiniest metal shaving will short out the coil.
Install new battery of same type. Handle new battery with non-metal tweezers
or rubber gloves, never bare fingers. Inspect case back gasket or preferably
just replace it with new o-ring of same size. Gasket should be lubricated
with silicone grease. Reinstall case back using wrench. If you are
concerned with water resistance the watch needs to be tested in a pressure
test machine. I'm sure the pros have more tips but this should suffice for a
Timex where it would not be a big loss to damage or break the watch.
i hope you can successfully replace the battery
thank you
Sep 06, 2008 | Timex Digital Expedition watch
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Have timex watch had battery replaced and watch quit working, she had to use clamp device to instal battery
If you had the battery replaced, I'm guessing that the watch wasn't working when you brought it in for a new battery. It may not have needed a new battery. You might need a new watch. I've never heard of anyone needing a clamp for a Timex digital watch. In my experience, they use phillips screws to hold the back to the case. I have a case press for snap-on backs, but that's still unusual for a Timex unless it has a BIG case. I think your watch was shot before you replaced the battery.
Apr 26, 2008 | Casio Atomic-Solar Watch GW300
Watches Logo
15 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
