Question about Sony Televison & Video
Have a Sony Flatscreen hooked up to cable. Is it possible to hook up the sony dvd player to them and how
SOURCE: DVD picture flashes on & off
our problem was because the hdmi on reciever was not compatable with hdmi on dvd player, different versions ex. 1.2, 1.3 , 1.1
ended up using component inputs instead
Posted on Feb 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: LOST INSTRUCTIONS HOW TO HOOK
Sony maintains most manuals on their website. The general principle is to hook the cables from the video and audio OUT of the DVD/VCR player to the video and audio IN of the TV. Once the cables are hooked up correctly, just press the input, source, av, or video button on the tv or tv remote to change the television to the correct channel so that you can watch videos.
Posted on Jun 14, 2008
SOURCE: Monster Component Cable labled Y/Cb/CR to TV that has Input Y/Pb/Pr
Y PB PR is the analog version of the Y CB CR color space; the two are numerically equivalent, but Y PB PR is designed for use in analog systems whereas Y CB CR is intended for digital video.
Posted on Sep 22, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
dvdcdlaser
  • 1285 Answers
SOURCE: I need to hook up the dvd player to my new Sony
you have a flat screen, look on the back of the flat panel for digital in (yellow, white & red jacks). this will be connected to yes the DVD player. using your tv remote switch the source enable to watch a DVD. you comcast cable is still connected to watch this simply switch back to cable source..
Posted on Jul 19, 2010
Testimonial: "I actually have not turned it on yet, but will later. Thanks, RW~"
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
Jul 19, 2010 | Sony DVP-NS50P DVD Player
Trying to hook up Phillips DVD player and have 3 coaxial cables that need to be hooked into Sony TV and I have 14 holes for cables-help!
Don't use co-axial cables buy HQ SCART Gold Plated Ribbon cables with full 21pins then hook up the AV out of the DVD player into one of the AV in on the TV.
When you turn your player on it will autoselect the correct AV (audio visual) channel on the TV.
Feb 12, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HDMI not working Sony BDP-S350
With sony products sometimes you have to use sony parts to get it to work. I would suggest to buy a sony HDMI cable and see what happens if that doesn't work then take the player back to the store because you got a faulty player.
Jan 08, 2009 | Sony BDP-S350 Blu-Ray Player
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
BLue ray DVD player
I am not sure about the Sony BDP-S300 Blu-Ray Disc Player: But the Samsung BD-P1000 Blu-Ray Disc Player requires HDMI cable
to give the best resolution (1080p) possible that the TV set is able
to support. Hope this helps.
redthroat@hotmail.com
Nov 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
LOST INSTRUCTIONS HOW TO HOOK UP MY DVD & VCR PLAYER TO MY TV SONY?
Jun 14, 2008 | Philips Televison & Video
No signal
can you double check the signal cable that its going to the right place?
I beleave its hooked up wrong.
Jun 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
