Question about Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer
Poulan 2150LE. Need throttle setting
Need factory screw setting. I cant start the saw and my ajustment is way out. Thx
  • 336 Answers
Hi there, there is no factory setting or mark. Just adjust it the screw yourself and stop when idling already. Here is how..
Idle Speed--T
Allow engine to idle. If the chain moves, idle is too fast. If the engine stalls, idle is too slow. Adjust speed until engine runs without chain movement (idle too fast) or stalling (idle too slow). The idle speed screw is located in the area above the primer bulb and is labeled T.
- Turn idle screw (T) clockwise to increase engine speed.
- Turn idle screw (T) counterclockwise
Posted on Jul 20, 2009
  • jeep brainy Jul 20, 2009
    Idle Speed--T
    - Turn idle screw (T) counterclockwise to decrease engine speed
Carb ajustment
Only Info I see is "Homelite Chain Saws" - not much to go on.
Most saws have two carb adjustment screws, Hi, and Lo.
Assuming the saw will start and run enough to warm up, then
adjust the Lo screw in, clockwise, until the motor starts to slow down,
turn only about 1/8 turn at a time. From the point where it starts to slow down, turn it out about 1/4 turn. This should give you a decent idle. Now pull the throttle, and see what happens.
A - Saw runs up to speed, but dies off, or starts to slow on it's own.
turn Hi idle screw out about 1/4 turn.
B - Saw speeds up, but runs sluggish, fat - not real hi end.
Turn Hi screw IN, about 1/8 or so, and try again, or adjust
while running at full throttle. (best way)
IF it won't run well, try turning both screws all the way in to seat them, then come back out about 1-1/2 to 2 turns. this should get you in the ballpark to set things up as above.
Once the saw is running well, adjust the idle screw to a smooth idle but slow enough that the chain stops moving.
Stay safe
Jul 01, 2012 | Homelite Garden
Hi, I just cleaned my Poulan Pro. Changed out the gas, opened the carb and flushed it out with fresh gas, cleaned the fuel lines, the spark plug and air filter. I didn't replace the fuel filter though. ...
The fuel pick up or filter should be changed every year but if your saw will start and run good but just not idle then adjust the screw marked T counterclockwise slowly until chain starts to rotate without you depressing the throttle.At that point back it off about 1/16 of a turn until saw will idle but chain doesn't move.Thank you. P.S. If you want to you can go back to factory setting by turning H & L fully closed then open 1 to 1 1/4 turn and very slowly adjust for smoothest operation. Do not adjust H anymore then minimum off factory to avoid engine damage.
If you need further help I would suggest you have a trained tech.service it. Good luck.
Feb 14, 2011 | Poulan Pro Chain Saw 46cc 20"
FUEL MIXTURE SCREWS BEEN ADJUSTED IMPROPERLY. WHAT IS PROPER HIGH -LOW CARB SETTINGS FOR 40CC POULAN CHAIN SAW
Make sure the air cleaner is not plugged. Turn both jet screws CW to stops (lightly), then back each out 1-1/2 turns CCW. This is a basic setting and should allow the engine to start and run. When the engine is warmed up, pull the throttle full on and adjust H jet needle CW until the engine starts to speed up, but still 4-stroking. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and allow to idle. Turn the L jet needle CW until the engine idles fairly well, but the engine should 'follow the throttle'. It will tend to 'gasp' when pulling the throttle if you have gone too far. Idle speed screw should be set so that the chain doesn't try to turn, but the engine continues to idle. Hope this helps!
Jan 04, 2011 | Poulan Pro Chain Saw 46cc 20"
Hi, on a poulan Titanium chain saw, what is the carb ajustment? Thanks Douglas Neil
Turn both jet screws CW to stops (lightly), then back both out 1-1/2 turns CCW each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on--the engine should 4-stroke. Adjust the H needle CW until the engine speeds up somewhat, but continues to 4-stroke. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW until the engine runs fairly well, but still allows the engine to 'follow-the-throttle'. Adjust idle speed so that the chain stops turning, but the engine continues to run. Hope this helps!
Jun 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Have a poulan chainsaw that won't idle/stay running and bogs down when you press the trigger control. Do you need a certain wrench to adjust carb??
no carb ajustment is done with a flat head screwdriver, first i would remove the card, disassemble it and blast it with compressed air because its probably just clogged up with varnish. to ajust the high low and idle screws bottom both out ( turn in all the way) then unscrew each one turn. from there start the saw and loosen in 1/4 turn at a time until it runs well
Apr 25, 2010 | Poulan Pro Chain Saw 46cc 20"
My poulan wild thing 2375 bogs out when throttle
Make sure that the air cleaner and muffler are not plugged. Check the carburetor screws and nuts for tightness. After turning both needles CW to stops (lightly), back them out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H needle CW somewhat until the engine speeds up, but is 4-stroking. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW till the engine runs fairly smoothly, but allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine keeps running. Hope this helps!
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Saw will start an run short period and stop.Only start when adding gas directly into carberator. This is a Poulan 16 chain saw.
If it is a old saw it sounds like your engine seals are failing. when a engine seal fails it allows air in past the crank upsetting your fuel mixture You could try to richin the fuel mixture by turning the screw marked H anticlockwise a quarter at a time untill it runs Ps to set (h) screw to factory, screw it in til it stops then unscrew it 1 & 1/2 turns
Sep 25, 2009 | Poulan Garden
Wood shark 2150 not oiling
Your model is a 2150LE. There is a Type 1 and 2. The linked IPL is a 2150LE Gas Saw Type 1. Click the "View the illustrated parts list [Go] button here:
http://www.ordertree.com/modelinfo/PWE/2150LE-Gas-Saw-Type-1/75.2150LE-Gas-Saw-Type-1.1.59.1.html
What little detail there is is on the "Handle, Chassis, & Bar" drawing.
A blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. The oil pump (52) is often behind the clutch. The saw can be operated without the bar and chain to verify oiler operation. GL
Lou
Sep 17, 2009 | Garden
Need chain saw fix
I would try Poulanpro.com and look at their user manuals for the adjustment. They are different on most saws. Hope this helps
Mar 11, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan Pro Pp125 25cc Gas Straight Shaft Attachment Capable String Trimmer Logo
152 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
