LE code. Changed RPS sensor. still wont spin Ran a cycle without detergent Still won't spin
  • 130 Answers
SOURCE: LE code -during cycle the drum doesn't spin but just clicks
http://www.howtomendit.com/answers.php?id=28214
click the link directly
Posted on May 07, 2009
GodBlessU
  • 3513 Answers
SOURCE: washer wont run spin cycle model 417
The reason for your washing machine not to spin would be of a faulty motor coupling.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Thank you for contacting Fixya.com
Posted on Aug 11, 2009
matrixgent
SOURCE: LE fault code for LG WD-1019bd washer
I found that in winter time not a problem with my LG front loader, but when the temperature went over 30 Celsius the problem came back and intermittent like yours did, there was also an unusual noise coming from the machine.
What I did to fix the problem was to remove the stator and place it in the freezer for about half an hour or so, I also cleaned any minor dust and grit from both the Stator magnets and the Stator drum, replaced it still very cold and now it works well with no more unusual noise and the outside temperature has no more bearing on the machine not spinning this day!
I hope this helps!
Regard
Andre’
Posted on Dec 09, 2009
  • 6277 Answers
SOURCE: Have LG WM2277 with constant LE code. Already
'LE' on LG's indicates Lock Error indicating there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention.
Hope this helps ;-0)
John C
Posted on Mar 06, 2011
Jahn27
  • 1554 Answers
SOURCE: I have an elite oasis
The dreaded fault codes F50 and F51 on these machines including its Whirlpool and Maytag counterparts Cabrio and Bravos, respectively, are found to be due to an intermittent connection at the Rotor Position Sensor (RPS). The early batch of these machines are installed with a machine/motor control board that is too sensitive to intermittent RPS connections. Recent batches are equipped new control that is designed to check the RPS sensor differently and is less sensitive to intermittent RPS connections.
Remove and reinstall the connector at the RPS several times to clean off any corrosion built up on the connector and RPS due to the intermittent connection. Confirm that the connector is fully seated onto the RPS control upon final connection and verify there are no damaged wires. If the problem persists, knowing that the RPS is good based on the manual motor and RPS diagnostic test, the problem now is between the control board and the motor. Measure the resistance between any two of the three drive motor terminals with the ohmmeter set to the R x 1 scale. The meter should indicate around 31 ohms in each of the three motor windings. Significant difference in the winding resistances indicates a motor stator problem. Consider replacing the control board ONLY after making the above troubleshooting and the RPS and motor turn out good.
Please accept the solution should you find it helpful and/or informative. Accepting the solution will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 10, 2011
My lg front load washer WM2016CW wont spin on spin cycle
LE is caused by one of two things
1. Using regular detergent, not HE detergent, oversudsing confuses sensors and you get the code or
2. (Most likely- the position sensor also known as the HALL sensor is bad and needs to be replaced. Easy fix. Part under $20.
http://www.ebay.com/itm/LG-Electronics-Washing-Machine-Rotor-Position-Sensor-Assembly-6501KW2002A-NEW-/262272820807?hash=item3d10ada647:g:az0AAOSwnLdWsMSa
check out out YouTube or repairclinic.com or appliancepartspros.com for videos.
Jan 26, 2017 | LG Washing Machines
Washer wont spin. F51 code
the f51 error indicates that your rotor position sensor) is not registering or it is just bad. try this, remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connections. after that go ahead and try to run a cycle. if you continue to receive the error then you need to replace the RPS sensor. Here is that part to order. Whirlpool W10178988 Sensor AppliancePartsPros com
Oct 05, 2014 | Maytag Bravos MTW6600T Top Load Washer
LE error on washer. What can I do without a tech?
The *dreaded* "LE" error is overwhelmingly caused or triggered by incorrect type detergent **OR** too much *HE* detergent (a special low sudsing detergent).
In all LG washers-when too much detergent has been used-this will cause the "LE" error to be displayed & the wash cycle will be interrupted. Unplugging the washer for more than one minute will cause the MAIN BOARD (computer) to power down and re-boot when the washer has been plugged back in.
On LG washers built *before* 2008-after several "LE" error events-the error *cannot* be reset by unplugging the washer. This indicates that the HALL EFFECT SENSOR has failed and will need to be replaced.
On all LG washers built during and after 2008-a more robust resistor was used in the HALL EFFECT SENSORS-which eliminated damage caused by higher electrical loads placed upon the sensors due to oversudsing. HALL EFFECT SENSORS virtually never fail in 2008 and newer LG washers but the "LE" error will still occur if too much or the wrong type of detergent is used. This will be "resettable" by unplugging/replugging the washer.
The CORRECT amount of HE (High Efficiency) detergent to be used is as follows:
HE : (2) Tablespoons Per Wash Load
HE 2X : (1) Tablespoon
HE 3X : (1) Teaspoon
USE THESE AMOUNTS RELIGIOUSLY-NO EXCEPTIONS-IN ALL FRONT LOAD WASHERS WITH 3.0 cu ft DRUMS AND LARGER
Read more: The Dreaded LE Error Code in LG Washing Machines: Diagnosis / Troubleshooting, Root Causes, and Repair ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2010/08/03/the-dreaded-le-error-code-in-lg-washing-machines-diagnosis-troubleshooting-root-causes-and-repair/#ixzz2nlabX1Gv
Follow us: fixitnowsamurai on Facebook
Dec 17, 2013 | LG WM2233H Front Load Stacked Washer /...
Annoying LG Tromm wm2277hw "LE error" won't go away.
Might be "tE" error code. Thermistor error. A $6 parts and pretty common and causes the symptoms you described.
Mar 02, 2017 | LG 4775er2002a Door Hinges for Wm2277hb...
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
Hi there my 5 year old machine has started showing error code LE with 3 minutes on cycle left and will spin on seperate spin but is not draing properly is the pump gone ???
No, it is a problem with the motor. The warranty should be 7 years. Check your manual. There is an electronic RPS sensor that is usually associated with this error code and is located behind the motor. It is also something that should be, part wise, covered. Labor will be charged.
Nov 20, 2010 | Washing Machines
Cabrio washing machine wont finish spin cycle and comes up with a code blinking F 51. how do i fix this problem I cant finish one load of laundry, without this cod F 51 poping up. thank you wendy
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems.
Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code le for tromm washer
TWhen you receive the LE error code, unplug the machine for approximately 15 - 20
minutes. This will reset the microprocessor.
The LE error code can be an indication of several different issues.
The most common cause is over-sudsing in the machine. Many times owners
experiencing the LE error code are using regular detergent. It is recommended to
use a high efficiency or low sudsing detergent. Many of the leading detergent
manufacturers have a high-efficiency (HE) selection. The HE detergents are
designed for lower suds levels and enhanced cleaning performance in
front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. A
good rule is to load the washer until the clothes in the drum are no more than
three-fourths of the way up the window of the door. This will allow them
sufficient room for tumbling. The clothing having sufficient room to tumble is
more important than either the weight or the number of items in the washer. It
is the tumbling action that provides the washing effect.
Lastly, a breakdown in the signal between the microprocessor and the motor may
cause the error code. This can occur if there is a loose wire, dislodged ball
sensor, or if the shipping bolts are removed prior to situating the washer. . In
this case, a servicer would need to take a look at the unit. In this case, you
will need a service center to look at your unit. For service assistance, please
visit our website at us.lgservice.com Click on "Service Center". Enter your
zipcode and product type. Click search.
In the event that you cannot find a service center, please call 1-800-243-0000
for assistance. There, an agent will be able to provide you with an Authorized
LG Service Center in your area.
Please have your model and serial number available along with your zip code when
you call. If you have a customer service issue, please let the agent know and
they will set up a customer service file for you. If your unit is under the
factory warranty, your purchase receipt will validate the warranty.
Business hours are 24 hours a day, 7 days a week. too many soap suds.
Please rate my hyelp++++Thanks for using FIXYA
Jun 25, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Code LE, will not finish the spin cycle
It's very important not only to use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect dosage instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Apr 01, 2010 | LG WM-2277HW Front Load Washer
Code LE comes on my washer it is a LG wm2075cw
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 17, 2008 | LG Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
