Question about Toshiba E-Studio 3040c Color Copier
How to fix error code c449 for Toshiba E-Studio 3040c?
  • Toshiba Master
  • 647 Answers
Clean themopiles
Posted on Sep 10, 2017
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
  • 990 Answers
SOURCE: error code c440
Hello sir; C440in this machine,it means fuser unit problem, but it can be reset the procedure as follow;
1, hold down "0" and "8" keys while turn on the power.
2, enter 400 press start.
3, enter 0 press set or enter.
Posted on Jan 07, 2009
  • 647 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
  • 19 Answers
SOURCE: Hello, I turn on my Toshiba E-Studio 166 Photocopy
Poor contact of the fuser drawer connector may cause the following
error codes: C41~C46, C4A, CD5, E01, E03. To correct this issue, a
spacer (see SPL p25 item 1 attached) has been added between the
fuser connector and the frame; also the springs (see SPL p24 item 8
attached) have been changed to provide more tension.
This change has been applied since January 2003 production:
e-Studio 550 TA314824
e-Studio 650 WA312627
e-Studio 810 XA311627
Model P-I Before Change After Change
e-ST550 25-1 --- 6LA14365000
e-ST650 SPACER-DRW-CNCT
e-ST810 24-8 6LA08946000 6LA14468000
SPC067-070-140 SPC068-080-160
Posted on Jan 26, 2011
SOURCE: How can i fix the
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Posted on Dec 04, 2012
How do I print from a USB flash drive to a Toshiba Studio 3040C photocopier
insert the drive into the usb port hit print choice find usb open it select your file hit start
Apr 07, 2017 | Toshiba E-Studio 3040c Copier
What does error code CE 40 mean on a Toshiba e-studio 3040c and how can it be fixed
U need to see it happen on which process unit, then check the main charger unit and developer material is enough...
Apr 07, 2015 | Toshiba E-Studio 3040c Color Copier,...
C449 error code in toshiba e studio 2540c
error C 449 Heater lamp abnormality after abnormality judgment (temperature abnormality at high temperature)
first of all just reset error with simulation may just malfunction error procedure for rest error for heater related.
turn copier off
hold down 0 & 8 while turning it on power switch
then press digit numbers 4 0 0 then press start key
then 0 key and set
Jul 26, 2014 | Toshiba e-Studio 2540C Multifunction Color...
F900 error code, how to fix
F900 is Model Information Error
Perform SRAM-Re-Initialize Support
If cannot, perform Key FROM to SRAM
Jan 24, 2014 | Toshiba E-Studio 3040c Color Copier
How do you print an envelope on toshiba 3040c printer?
usually to set it up to your computer there should be a program which shows how to do it . Microsoft office under mailings shows an envelope picture, try that To put the envelopes in the printer there is usually a picture where u put the paper it will show which way to place the envelopes.
Aug 18, 2013 | Toshiba E-Studio 3040c Copier
Error code status 4011
Error 4011 indicates that a job has been deleted at the machine console from the job list.
Cheers
Daren
Mar 26, 2013 | Toshiba E-Studio 3040c Color Copier
Toshiba E-Studio 3040c Color Copier Logo
235 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
