The fan light and the lock button light up red when I try to start it
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: flashing lights with no fans, held power button down & now only red lights (internet adapter, volume button) & fans are working why? help?
this sounds like a hardware or driver issue
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
test all leads that attach to your hard drive including electrical extensions
the leads from your ((motherboard to your hard drive)) Sata make sure they have dust free secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
if you remove the graphics card to clean the socket replace it
restart the computer the found new hardware wizard should activate
or you might try
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Posted on May 10, 2012
Changed prosser fan now pc wont start
These fans are very tricky to install, they must be mounted in the proper holes and locked into place, there are many different methods of completing this depending on the manufacturer of the motherboard/fan. On the 4 corners of the fan there should be the locking mechanism, usually something that will need to be pressed into the hole then twisted to lock, all 4 must be secure and equal pressure on each. Check with motherboard/fan manufacturer to see the proper procedure. If you removed the CPU check that the pins are not bent and that the chip is locked into place with it's proprietary locking mechanism. If pins are bent take it to a reputable repair shop, don't try to straighten them out yourself unless you are experienced in this.
Dec 20, 2013 | E-Machines eMachines Desktop PC
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 30, 2012 | Maytag Washing Machines
Press start button, fan trys to start, green light comes on then changes to a red flashing light
If your fan is trying to start up but won't, your system is going to give you a warning and most likely shut down. Make sure you have good connection for fan power and that it is clean and can turn freely. You may want to cosider replacing the fan.
Apr 09, 2011 | Compaq Presario 5000 PC Desktop
Lock on button flashing red light. No power to start
Press and hold the NO Heat button to unlock.
Sep 21, 2009 | Dishwashers
Lap top can not start even button lights
do static discharge
disconnect battery and all peripherals. disconnect from mains. press power button and hold for 30 sec.
Connect to mains and try to turn on again
If it will not start - mainboard needs replacement
thanx
Sep 14, 2009 | Toshiba Satellite M40-S417TD Notebook
When red light is flasing on and off what may be the problem? on epson scanner
If the start button light is flashing red, it is because of one of the following problems:
  • The scanner is not connected to your computer properly or your software is not fully installed.
  • The transportation lock is locked. Slide the lock to the unlock position.
Aug 23, 2009 | Epson Office Equipment & Supplies
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
