Question about Miscellaneous
Is tocolysis capitilized? Is it a generic or brand name **** used in obstetrics.
Generic drugs
You did not ask a question, you just stated "generic drugs". In many cases prescription generic medications have almost the exact same ingredients as name brand drugs. However, this is not always the case. Some generic drugs contain different fillers than name brand drugs, and this results in allergies or sensitivities among people who might be fine with the name brand medication.
If this does not answer your question, please feel free to expand on your question as "generic drugs" in of itself is not a question.
Mar 28, 2017 | Health & Beauty
When do you capitilize it's
Capitalize it if it's the first word in a sentence.
Oct 07, 2014 | Avanquest Fix-It Utilities 8 Professional:...
What brand name of spark plugs for trailblazer
The Brand name does not matter but I would choose bosch, champion, autolite or any other name brand, not generic. Just make sure that they are the right one for your year, make, model and engine size.
Jun 14, 2014 | 2002 Chevrolet TrailBlazer
My kodak z740 will not turn on when i put the batteries in
Hope you are using high quality name brand batteries. The generic brands do not have the power to boot the unit. If you are using good batteries then the camera needs service / repair. no consumer fix .
Oct 13, 2012 | Kodak EasyShare Z740 Digital Camera
My Bostitch SB 2in1 nailer will only on occation nail all the way into the wood. For the most part the nail will bend over before it goes in, which damages the wood. I spend more time tying to pull out...
I ran into this problem many times. Don`t use the Bostitch brand nails. Use the generic or other name brand. You`ll notice the generic one`s heads are just a little bigger and the driver blade won`t run down the side of the nail!
Jan 05, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Replaced ink in printer with generic ink cartridges and error message 1203 came up.
A person might notice that buying new, name brand, ink cartridge for printer rapidly becomes quite an expenditure. Nonetheless, there are quite a lot of different methods to find the equal quality standard for a alot lower price. Your primary options are: name brand (OEM) ink cartridge for printer, matching generic ink printer cartridges or remanufactured ink printer cartridges.
When you are purchasing a replacement photo printer cartridge, consumers do have choices. It’s frequently assumed that shoppers are required to buy the expensive, name brand, cartridge for laser printer from the manufacturer, or the service contract will become void. Their belief merely is not correct. By law, the use of compatible replacement inkjet printer cartridges does not render null and void the printer makers guarantee. In truth, you can choose to get less pricey compatible cartridge for laser printer, or remanufactured cartridges, often with a realized savings of between 40% and 75%. All chief ink laser printer cartridge brands have matching versions, including IBM, and Xerox.
Name Brand Inkjet Cartridge for Laser Printer
Nearly all major makers of laser printers also create the replacement inkjet printer cartridges that are best matched for their particular laser printers. This option is ordinarily the most expensive, and in a lot of situations it is the lone choice available if you happen to get a new laser printer whose producer implanted computer chips in the ink printer cartridge. The point of this chip may possibly be to regulate the color ink flow, limit the cartridges use, or to standardize the cartridge in alignment. Nevertheless, if you pick out a similar, or remanufactured, cartridge for laser printer, it might not be able to interconnect with the laser printer and may harm the laser copier or cause it to quit working.
Comparable Generic Inkjet Cartridge for Laser Printer
When thinking about purchasing an ink printer cartridge for your laser printer, the key aspect you must to bear in mind is the price. Buying a brand new ink laser printer cartridge will be based upon how much you are prepared to give. You can buy a new brand name cartridge for printer, or you might purchase a new compatible (generic) ink printer cartridge. Both types of ink printer cartridges might provide you with the same quantity, quality and performance you insist on from your printer. The major difference is in cost: a brand name ink printer cartridge might easily cost nearly twice the price of a compatible cartridge for printer.
Compatible (generic) inkjet laser printer cartridges are made to meet OEM (Original Equipment Manufacturer) specs. These makers usually set very lofty standards of dependability and quality and also provide high quality results, regularly exceeding the quality specifications established by the OEM. These cartridge for printer are produced with new parts and are a lower priced option to costly name brand ink printer cartridges.
Buyers might also be surprised to see that the generic comparable cartridge will publish the same amount of, or more, pages than the original OEM cartridge. Largely, this is since certain original OEM ink laser printer cartridges are not filled all the way up. In this situation, a compatible ink cartridge for printer could give you twice the advantage: it reduces your price per cartridge and cost per page by printing additional pages
Dec 27, 2009 | Dell 926 All-In-One InkJet Printer
What oil to use
50:1 ratio of a good quality oil, STIHL, McCullock, Homelite, Husqvarna
If you cannot find a name brand saw oil, then 32:1 of generic brands.
Nov 22, 2009 | McCulloch Garden
Need oil gas mixture
Using a 'name brand' 2 cycle (STIHL, Husqvarna, TORO, ect) oil 50:1
Generic brand 32:1
The bottle will tell you how much to use depending on it's concentration and the amount of gasoline.
Nov 15, 2009 | Homelite Consumer Products MightyLite...
Depend, buy the brand name light or generic lamp.Brand name $100 to $150.
Oct 31, 2009 | Zenith E44W46LCD 44" Rear Projection...
Canon MPC5500 using an Apple M3240 blk cartridge???
May be the same cartridge, but several brand name cartridges have computer chips is them that may not recognize other brand name cartridges, even though the cartridges may look identical.
Canon use to make all of the apple printers back in the day when apple actually sold name brand printers. That been awhile though... long while. The apple cartridge has to be really old stock.
I would take it back and request the name brand cartridge or at least a generic one that says it is compatible with your printer.
Hope this helps.
Mar 07, 2009 | Canon Office Equipment & Supplies
Miscellaneous Logo
15 people viewed this question
Top Miscellaneous Experts
Randy Hughes
Randy Hughes
Joey Gammon
Doug Davis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
