Question about Samsung Electronics - Others
How do I add additional memory to my Samsung SM-T710 reader? What little I can find tells me I can add up to 128 GB with an optional MicroSD card.
  • 64 Answers
MAKE SURE YOU TURN OFF YOUR TABLET before adding MicroSD card storage.
Your Samsung SM-T710 Galaxy Tab has a place for a MicroSD card on the lower edge of the unit below the volume button.
You will see a small hole. If there was no 'tool' included with your tablet, you can use the end of a paper clip bent out to create a small stiff wire you can use to insert into the hole.
Once you insert the tool/paper clip into the hole, the tray which is used to hold the MicroSD card will pop open.
When you have purchased your MicroSD card, you can insert it into the tray (it is 'keyed' to only fit one way in the tray). Then push the tray fully back into the slot, and your new storage should be ready to use.
Once you turn on your tablet, the tablet should recognize that you have new storage. It may ask you to 'format' the card.
You should explore options in your Settings to have your tablet use the new storage as the default destination to store music, pictures or videos. And it may allow you to install new programs to the SD card, saving space on your tablet's internal storage for the operating system.
Posted on Feb 12, 2017
  • 94 Answers
SOURCE: cannot add music onto blackberry curve 8310 with sandisk 1 gb memory card
pls format the card from the blackberry device.
this should take care of the issue
Posted on Apr 28, 2008
SOURCE: unlock 1 GB micro sd memory card of Kingston Made
my memory card is locked .i use a nokia 3110c model. please give me the solution
Posted on Oct 31, 2008
Posted on May 12, 2009
SOURCE: Unable to add default folder - Memory Card
take the card out and put in back in. it worked for me,
Posted on May 30, 2009
unlock password of micro sd card
Posted on Jul 16, 2009
I need a User Manual for a Samsung tablet - model SM-T710
Try Googling (Samsung)(SM-T710)(manual) without parens.
Jun 09, 2017 | Samsung Tablets & eReaders
Installing additional memory into my Jitterbug smartphone--How do I do it?
Per the Jitterbug Smartphone manual, on page 124:
Adding more Memory Your Jitterbug features a microSD expansion slot to add up to an additional 32 GB of memory. The following is how to add more memory:
1. Remove the Back Cover using the Back Cover Release notch found on the bottom corner.
2. Locate the microSD expansion slot, which is below the External Speaker, and carefully insert the microSD card into the expansion slot until it clicks into place.
3. Replace the Back Cover.
IMPORTANT! Do not remove the SIM Card located opposite of the microSD expansion slot. Tampering of the SIM Card may cause issues with connectivity to the GreatCall network.
May 19, 2017 | Cell Phones
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
Add music directly from mac?
If your Mac system has a MicroSD reader, you can add music directly from MAC to the MicroSD Card. You can also insert the MicroSD card into USB compatible phone connect the phone to your MAC and Load your Music to your MicroSD card.
Jun 01, 2010 | PNY 2GB microSD Memory Card
What is the most capacity of Micro SD that suport of that cellphone!
The SDA announced the microSD format at CTIA Wireless 2005 on March 14, 2005, and approval of the final microSD specification was announced on July 13, 2005. At launch, the microSD format was available in capacities of 32, 64, and 128 MB. SanDisk introduced a 2 GB microSD card in July of 2006, initially priced at 99 USD. Since then, prices for flash memory devices have fallen dramatically. The same 2 GB card as of April 2009 can be found for as little as 12 USD at department stores, and as of May 2009 for as little as 6 USD at online electronics stores. At present date Jan 2010 a 16 GB micro SD card class 2 comes for about $40 and a 4 GB class 2 micro SD card comes for about $8.
please rate my answer as helpful. thanks. Joe
Feb 23, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Transferring music files to microSD card
It says on the manual this this phone accepts microSD™
memory cards up to 2 GB (depending on memory
card manufacturer and type). Check with your phone manufacturer if there are known issues with a particular memory card brand.
Also, try connecting the memory card to your computer via memory card reader and see if the card will be detected. That way, you can check whether the card is working or not. Save the music files from the PC to the memory card, then see if the music files will appear when you insert the card to your phone.
Jun 20, 2009 | SanDisk 2GB microSD Memory Card
How do u format sandisk microsd 2gb and microsdhc 4gb disks
You can only form sd Hc if your card reader is approved for SDHC use. It should tell you that on the outside of the card reader or in the documentation of the card reader.
If your drive isn't formatting 2gb, it could be that the driver was designed prior to 2gb cards being released. You could look for a new driver or replace it with a card reader that supports SD HC use as will as a 2 gb SD drive.
Nov 12, 2008 | SanDisk 2GB microSD Memory Card
Flash memory problems
When I put in extra 1 gig of memory on my 1 gig unit and then looked at it in my computer the extra memery showed up as another drive. I had 1 gig from the unit as 1 drive and on another drive I had another 1gig
Aug 21, 2007 | RCA TH1101 MP3 Player
Electronics - Others Logo
1,445 people viewed this question
Top Samsung Electronics - Others Experts
Jeff Sterrett
Jeff Sterrett
Tom Chichester
Are you a Samsung Electronics - Other Expert? Answer questions, earn points and help others
