Question about home Audio Players & Recorders
Will they be any ht 3916 home theater rem it available anytime soon
techman
  • 3130 Answers
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
Posted on Oct 15, 2007
easyq
  • 144 Answers
SOURCE: HOME THEATER SAMSUNG HT-Q100
Your systemn is designed and built to perform 2.1 sound. If you want 5.1 sound you can do 2 things, connect another pair of speakers to the same speakerterminal as your front speakers, however this produces 5.1 stereo sound and not 5.1 surround sound.
You can buy a new system that has the proper connections.
This set will not have the proper decoding software to produce 5.1 surroundsound. sorry.
Posted on Jan 18, 2009
sandipmistry
  • 56 Answers
SOURCE: need code to program other remote
For this reason, no one can help other than the SONY AUTHORISED PERSON. These codes are not given to customers or any other personnal other that SONY PERSONNAL. So you need to contact your neartest SONY SERVICE CENTRE.
Posted on Apr 23, 2009
SOURCE: I need a replacement remote for a Durabrand Home
I found one to purchase online.
Posted on Dec 03, 2009
dunnbiker
  • 8546 Answers
SOURCE: My durabrand home theater system will not turn on
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Sep 04, 2011
Need manual for ht-3916 durabrand home theater system
Google (durabrand)(ht-3916)(manual) without parens.
Jun 06, 2018 | Audio Players & Recorders
How can i get the speaker terminals to put out sound n not static on a home theater system model # ht-3916
without knowing the exact model i can only guess that by static you mean that you turn the volume right up and get white noise. turn it back down and work out why the sound from the input is not selected and getting to the output
Mar 20, 2014 | Audio Players & Recorders
I need the remote codes for a Samsung AH59-02291A
The Samsung AH59-02291A remote came with several Samsung Home Theater systems, including the HT-H4530 and the HT-H5500W. The remote is not a universal remote and will not control other devices. You can learn a bit more about the remote by looking at the manual for the home theater system that it came with. The HT-H5500W manual is available on that product support page: https://www.samsung.com/us/support/owners/product/2014-5-1-channel-blu-ray-home-theater-system-ht-h5500w. If you need a universal remote to control the home theater system, look for one manufactured and programmed after 2014 for the 2014 HT-H5500W.
I hope this helps.
Feb 02, 2011 | Samsung Remote Control Remote Control
Looking for replacement remote control for durabrand ht-3916 ..unit was given to me without remote and new this unit only cost $40. I don't want to buy remote that is as much as a new unit
logitech has a really good lineup of universal remotes..it could also make ur life easier with the other equipment in ut house.
http://www.logitech.com/index.cfm/remotes/universal_remotes/&cl=us,en
Aug 05, 2009 | Audio Players & Recorders
Need code to program other remote
Apr 22, 2009 | Audio Players & Recorders
37 people viewed this question
Top home Audio Players & Recorders Experts
Lawrence Oravetz
Johnny Massengill
Johnny Massengill
Are you a home Audio Player and Recorder Expert? Answer questions, earn points and help others
