Question about Inverter Heating & Cooling
How to repair or reset Code U4 in Daikin mini split Inverter 12,000BTU? Thanks.
I had to disconnect the breaker and remove cables, for doing some repair work on the roof (not related to the AC) when I put them back and turned the breaker ON again, the indoor unit kept flashing. I found out it was code U4. I turned OFF and ON the breaker but nothing changed. I removed both PCB (indoor and outdoor) but could not find any obvious fault. I reinstalled everything back but again nothing changed. Curiously, while playing with the remote control, when going through the error codes, the unit started and began to cool. After about an hour, I stopped the unit to install the covers, etc. When I tried to turn it on again, about two hours later, the U4 Code came back again. The indoor fan unit works when I select the fan mode. Any ideas of what could be wrong? Thanks.
3 Suggested Answers
  • 659 Answers
SOURCE: carrier split 42G250HF-1(indoor unit
I'm not sure exactly what unit you have and what controls you have installed on the unit. But....there usually is a flash code schematic on the unit. Usually on the inside of the blower compartment cover. This should tell you what is wrong with the unit. It could have a low voltage short somewhere and is loosing the call for cool. So the answer can be a possible yes to your question but without knowing the flash code, it's hard to tell from my point of view. You might end up calling a service professional out to check it.
Posted on Mar 30, 2009
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
Hello Please How to solve DAIKIN U4 Error Code?
Looks like a communication error between indoor and outdoor units. Outside at the disconnect mounted on the house cycle the power. Leave off for 10 secs ish. See what happens.
Jul 20, 2017 | Heating & Cooling
Streamline. What does error E0 mean?
How to fault find a Daikin Air Conditioner, troubleshoot split ...
? 4:22
Feb 10, 2012 - Uploaded by Fully Airconditioned This video shows how to get fault code from remote control and reset fault, you ... Daikin Inverter AC Unit Fail - Moisture / Salts Damage to PCB ...
Sep 30, 2015 | Inverter Heating & Cooling
Error message U4
Signal transmission error. Indoor and outdoor PCB's cannot communicate. Usually a faulty controller board in the outdoor unit. If the indoor unit otherwise functions normally (can control fan speed, louvres, beeps in replay to all remote buttons) then it is probably OK so check outdoor controller PCB.
Jul 21, 2014 | Daikin Mini Split Concealed Duct Units
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Is there a reset button on daikin splits? If so where can I find it.? Fault code U4.
the fault code for daikin u2 is power supply is too low the reason for this is complexed and needs an expert to fix it
hope this helps in some way
Dec 02, 2010 | Cfm Daikin R410a Split System Air...
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Daikin air con - error code is u4
i need the contrl wiring of a packaged unit
Mar 07, 2010 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
869 people viewed this question
Top Inverter Heating & Cooling Experts
Are you an Inverter Heating and Cooling Expert? Answer questions, earn points and help others
