Question about GE Lands Phones
Intercom problem on one station but not the others for the GE 2-9451 four-line phone.
We have several stations set up on the GE 2-9451 four-line phones. One of the phones' intercom system doesn't seem to be working. The phone doesn't receive the incomming intercom, and the phone just beeps and stops the transmission. What could be wrong?
SOURCE: 3 Phones Need Repair
I am in Delhi....these phones can be repaired at a very low cost...where are the phones? BTW do yu have the manual? If yes can you share with me either scanned or point me to the web locator. Thanks in Advance
Posted on May 19, 2008
SOURCE: intercom
make sure each and every phone has its own ID. That solved problems for me for all but one phone.
Posted on May 22, 2008
SOURCE: Avaya phone system (business)
Is the time and date correct?
If, at a display phone, you press "feature 59", what does it say?
Which model do you have?
Posted on Jun 25, 2008
SOURCE: Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Posted on Aug 27, 2008
  • 1417 Answers
SOURCE: We have the Ayaya Partner system with the 18D
hello,
the problem of your phone is not from your side (phone)what you have to do to solve this problem can be view from two different ways
First of all put off the phone for some time allow it to get it resetting storage for about five minute then put it on again then if this did not solve then you can then
Secondly,on the customer care line i.e the service provider this call is free of change then tell the attendance the problem you will be has some or fell question like prove of ownership your location e.t.c., you can do this assignment(calling) with same phone or another.
thank you and thanks for using fixay.
Posted on Sep 27, 2010
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Lee
Jun 17, 2008 | GE RCA 4-Line Speakerphone
How can i transfer calls from one phone to another?
First make sure you give each phone an ID on your system. You do this by going into the menu and go to phone options then scroll down to phone ID then press the intercom station button you want assigned for this phone. To transfer call: With caller on the line just press transfer then the intercom station button of the room (intercom station) you want it transferred to. If it is not answered in 45 seconds the extension stops ringing and call is placed on hold
Dec 06, 2010 | RCA 25414RE3A - - Phone
The intercom light on my GE 2-9451 phone is flashing between green and red
This is what is in the user manual about the ligth means
Red Someone else is using the line.
Flashing red fast Incoming call.
Green You’re using the line.
Flashing green Line on hold.
Flashing red Line on hold by other stations.
Flashing yellow Incoming call transfer
Dec 18, 2009 | Video Game Consoles & Games
GE 2-9451
You need to have the phone join the network that you are in by assigning a station address to the phone. If this the only phone that you have like this, simply remove the plastic cover where the station addresses are to be printed. Beneath this cover there is a small button labled "PROGRAM BUTTON". Use a pen, press this button, then press "INTERCOM" and then label your station (01-16) followed by pressing the # key. This will make the intercom button flash on and off red and then it will stop flashing.
I hope this helps!
Aug 27, 2008 | GE RCA 4-Line Speakerphone
Intercom
May 01, 2008 | RCA 25414RE3 Corded Phone
Jan 06, 2008 | GE 2-9450A Phone
Intercom
Each of the six phones must have line 1 connected to the same "subscriber loop" (the same phone number). Assuming this is the case, and that you have not assigned any numbers to the the top six speed-dial buttons, each station will have agreed to be assigned a station number.
From any station, pressing the speed-dial button for another station's station number will page that station.
Now, how to properly initiate an intercom conversation differs between announcing to another station that a call is on hold, or a "cold call".
Oct 23, 2007 | RCA 25414RE3 Corded Phone
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Lands Phones Logo
44 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
