Question about Cameras
My hearing aids beep like the battery is dead although not exactly the same even with brand new batteries , I am thinking the beeps are some type of warning of technical problems
    Top Expert:
  • Cameras Master
  • 51,183 Answers
Take them back to an authorized hearing aid shop and have the fault checked out
Posted on Dec 15, 2016
How to stop dicon smoke alarm beeping
All smoke alarms beep if the battery is too low. Getting a used battery isn't good enough for smoke alarms. Even getting a new battery from a dollar store (a cheap no name brand import store) will not do... it has to be the newest and it has to be alkaline. once you put it in... press the button for 10 seconds... first you will hear it's own alarm then you will hear the others attached to it in the whole system chime in (if you have that type) the alarm will now sit quietly.
Oct 20, 2013 | Home Security
Reset gun safe combination
I have a similar safe, although it is a different brand. I have a red button under the top of the safe, around where the battery's go in. I have to hold that button until I hear a beep and a red light flashes. Then I'm required to input the new combination. This may, or may not, work for you.
I recommend contacting the manufacturer and asking them.
Apr 28, 2013 | Safe International Adg Sports Secure Vault...
Skytech 1410 fireplace remote (8 yrs. old) has stopped working. Replaced batteries in the transmitter. The red light lights up when
It may need to be re-synchronized:
Make sure the receiver's slide switch is in the REMOTE position.
Press and release the LEARN button on the receiver.
When you hear the "Beep", press and hold the ON or OFF button for about 2 seconds on the transmitter.
You will then hear a series of beeps that indicate that your new transmitter has been accepted by the receiver.
If you press the LEARN button on the receiver and you hear no beeps, the receiver is unable to retain any more transmitter codes
(make sure the transmitter battery is properly installed and fully charged).
To delete all of the transmitter codes on your receiver, press and hold the LEARN button for 10 seconds. Then you will hear a
series of beeps, indicating that the receiver's memory has been cleared.
It could also be dead after 8 years. A new unit can be purchased here: Skytech Remotes. I would even suggest on of the new styles with a built in timer or thermostat.
Nov 08, 2012 | Skytech 1001-A Fireplace Remote Control...
Quite awhile ago, one side of the unit went dead. Uesterday, after hearing a couple clicks, the unit will beep a few short beeps, then after a little bit, there will be a few short beeps again. I press the...
sounds like it is failing. When was the last time you tested its capacity? Test it to see how long the battery works. If it doesnt then get a new one or send it back where you got it.
Mar 09, 2010 | CyberPower 525SL (CPS525SL) UPS System
It's brand new, 4 beeps and a pause
check the user manual, but that battery will need to be charged for a period of time before it goes full load.
Dec 06, 2009 | Tripp Lite INTERNET550SER (S4863566) UPS...
When it is turned on it beeps 3 times and then turns off
Problem could be a bad battery. The beeps you're hearing could be a signal that power is low or almost dead. Assuming that your charger and the power/outlet in your house is fine, you could take a chance by buying a generic battery on the web. E-bay.com is a great source and usually they are pretty cheap. Try going to E-bay and type in your brand and model along with the word battery. By the way, I do not endorse E-bay nor am I affiliated in any way with the site or any of it's vendors. I just know they have many items such as the one you might need.
I Can Fix it
Aug 14, 2009 | Samsung Digimax S600 Digital Camera
Won't stay on even with new batteries- it beeps then turns off
my camera is doing the exact same n i'm hunting the net right now for some kind of solution!! :( i think its something to do with the lens, mine was completely stuck, but i gently pushed it n it went back in and moves in and out fine, but the cam still comes on for a couple of seconds makes this wierd beep n goes off again!
May 27, 2009 | Samsung S760 Digital Camera
Continual one time beeps intermittent
ahbma2000,
The hearing aids of today are digital and non digital programable. Older standard aids have a squeling problem as well and could sound like a beep. When the aids beep, its for a reason.
First an accoust beep, old or newer instruments could be because the ear piece or mold is not fitting property or your ear has accumulated earwax blocking the sound from entering the canal to the ear drum. Contact your provider to evaluate this.
On the other hand aids do beep to tell you 1) it is time to change the battery and 2) you are changeing from one program to another. Most programables are programed to beep when it first comes on also. Then it quits if all is well and you are hearing as planned. A review of you operating instructions will help to determine which problem you are having.
Thanks for contacting Fixya.com.
Apr 01, 2009 | Health & Beauty
I hear 5 warning beeps then a pause then 5 beeps again
Get the battery situated, and your beeps should go away. Sounds like an errant security horn from a sloppy connection. Interested to see what happens. TT
Jan 28, 2009 | 2001 Ford Explorer Sport Trac
Cameras Logo
46 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
