Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
JENN-AIR Oven shuts off and comes back on after several minutes
My Jenn-Air oven will heat up and work fine for a period of 30 minutes or so and will all of the sudden shut down. During the time the oven is shut down, the range top works fine. WHile it is shut down, none of the buttons on the front of the oven work and the display is blank. After a few minutes, the whole oven comes back on along with the fan. It will stay on for another 10 minutes or so and shut off again.
THe cable running to the fan appears to be connected fine as do all other visible plugs.
Any suggestions would be greatly appreciated. Thanks. Dan
  • 126 Answers
Re: JENN-AIR Oven shuts off and comes back on after...
They are equiped with a heat sensor it could be a bad thermastat(sensor) or
ventalation problem
Posted on Dec 10, 2007
0 characters
3 Points
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Electric stove works, oven turns on briefly then shuts down
Try turning off the power at the switch again and leave it off for a little while, sometimes the microprocessors become confused and need time to re adjust.
Apr 10, 2014 | Jenn-Air Kitchen Ranges
Jenn-Air oven shuts down after FC and F5 errors
Their was a good possibility that the solder could have been lifting of the contact points on the board, if the symptoms return i would check this, along with the said cleaning method :)
Mar 15, 2014 | Jenn-Air SCE30600 Slide-In Electric...
Re: Jenn Air #svd48600b Gas Stove Top works... Oven and Broiler not working(Elec.) I replaced Electronic oven control assy...It works correctly, but never gets Hot!! Any ideas??
Having a problem with the stove on this Jenn Air svd48600b.
Often with the oven warms up to 350F it starts beeping at and shuts off.
It flashes either just an FC error code, or FC and F5.
It is often possible to get the oven to work again if you wait 10-15min and cycle the power.
I imagine something is wrong with a heat sensor? The temperature sensor responsible for displaying temperature on the control panel seems fine though.
One other detail, even when the oven doesn't shut off at hot temperatures, the fan comes on (at around 220F) and stays on for over an hour after the oven is turned off.
Does anyone know if there is a different temperature sensor that might cause this? Is there a specific electronics board that may be leading to this problem.
when it heats up.
Aug 24, 2009 | Jenn-Air Kitchen Ranges
I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Jul 24, 2009 | Jenn-Air JES9800A Electric Kitchen Range
I was broiling on jenn-air convention oven on high about 30 minutes came back oven had turned itself off seem like it was overheated wouldn't allow you to do anything else
On this model there is a blower fan or cooling fan located between the cooktop and the oven. When oven temps reach @ 550 deg this fan should turn on to keep the controls cool. If it did not come on, you may have a bad fan thermostat or a bad fan. What happened is the control overheated and shut down on you.
Apr 10, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Oven fan won't switch off
it sounds like the clock on the oven has been adjusted, if the clock has been adjust the fan will continue to "Cool Down" the oven for the period set on the clock, it is also a possibility tht the clock is faulty, is the clock digital or Analouge
Jan 30, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
278 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
