Question about Sony KDL-50R550A 50" LED TV 1920x1080, 240 Hz, HDTV, 3D
Sony KDL-50R550A LCD TV: The bottom 65% of the screen drops by about 1/8" and becomes blurred. This lasts for about 2 seconds after which the image returns to normal for about 2 seconds.
It occurs rhythmically regardless of whether the TV has just been turned on or whether it is warmed up. It is also independent of Input selected. What board could be causing this?
SOURCE: clicking noise sony bravia kdl-40v3000
http://forum.ecoustics.com/bbs/messages/2/176039.html <-- Check that out.
Also I have a Sony Bravia and it clicks while it is on as well. I read that forum and some people said to disconnect the cable box for 10 sec. and then some said it was the heat from the summer.. i don't know.. I just turned my tv off and then back on and it stoped. I read this is happening with all kinds of TVs....
Posted on May 23, 2008
mistersony
  • 320 Answers
SOURCE: Sony KDL-32ML130 lcd tv
Not really that tough. Sounds as though the backlight is shutting down, either from a power supply failure, or a failure of the backlight circuit itself. You can verify this by holding a flashlight to the screen in the area where the menu usually appears to see if it displayed on the LCD panel with no backlight. If you can faintly see the menu displayed, your backlight has shut down and the most likely cause is the backlight inverter board, followed by the power supply and the backlights themselves which are part of the LCD panel. If you found this information answered your questions, please be sure to rate it. Thanks!
Posted on Oct 25, 2008
  • 267 Answers
SOURCE: Sony 46" LCD tv hdmi input replacement kdl-46v2500
replace that board
Posted on Mar 06, 2009
SOURCE: My Sony BRAVIA KDL-46V3000 Television has messed
This also happened to me and may continue to get worse... If it goes away for a while after warming up, then it is the same problem... The LCD panel is probably going out, when that happens the cost to repair it is more than the tv is worth... If it is in warranty then you can have it replaced or fixed.
Posted on Nov 23, 2009
Testimonial: "You were so right. Thanks."
SOURCE: Sony TV LCD screen blurred down one side when
My KDL-52W4100 just started doing the same thing. It blurs down the right side of the screen, then goes back to normal after it warms up. Does anyone know whats up with this?
Posted on May 25, 2010
Do you have a manual I can print off?
Sony has the manual for the KDL-50R550A on the product support site: https://esupport.sony.com/US/p/model-home.pl?mdl=KDL50R550A&template_id=1®ion_id=1&tab=manuals#/manualsTab . Look in the left hand column under Manuals for the Operating Instructions; if you don't see that heading, click on the Manuals, Specs & Warranty tab. The current direct link to this manual is https://docs.sony.com/release//KDL-R520A_R550A.pdf . You should be able to print the file from Adobe Reader or a similar program.
I hope this helps.
Jan 21, 2016 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
BRAVIA KDL-52XBR4 PARTIAL IMAGE DELAY
Three suggestions:
1. Try to hook cable direct without box to see if same problem---ie the box might cause this problem.
2. Check to see if it does it with DVD or when you change active inputs.
3. If number one contact cable provider as box may be your problem.
Mar 11, 2012 | Sony BRAVIA KDL-52XBR4 LCD TV
Hello, I've been given a Sony Bravia KDL-26ML130 LCD TV which is not working but I believe it may have a repair solution (hopefully!). The TV powers on fine but the display turns off just a second...
This tv problems are those long board call the LCD inverter boards,it is dead.TV should have 1 or 2 long boards that call the LCD inverter boards it it dead,these 1 or 2 long LCD inverter boards only job are to provide a backlight to the tv LCD screen panel to have screen light produce a picture.Tries websites like Shojimmy.com,Ebay.com to buy those refurbihes 1 or 2 long LCD inverter boards for the replacment.
Jun 18, 2011 | Sony BRAVIA KDL-46SL14098 LCD TV
Kdl32 m3000 white vertical lines through the 'sony" image on power-up and moving images are blurred or leave a "trail". Colors are wrong.
I'm afraid, it is problem of LCD Panel (screen) and it is very expensive part, replacement would cost you more then new tv price.
I'm sorry for breaking this news but have to say facts about problem.
Hope this will help.
Thanks.
Mar 24, 2011 | Sony KDL-32M3000 32 in. LCD Television
Guys, any suggestion for for this blurred down one side??? it happen evert day on my Sony TV. Can you please advise
if the video looks like it is dark on the one side and you can see image retention(ghost image of previous image after picture changes) and all inputs and menus are distorted then you most likely have an LCD panel failure and when it comes to repair unless you were able to get warranty coverage the repair would not be economical due to the cost of the LCD panel. i suggest contacting sony customer support for possible repair accomodation 1(800)222-7669
Jan 07, 2011 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Black Screen
Now turn on tv.Have picture flicker few sec.than dies,have sound only left?Yes,than the 1 or 2 long LCD inverter boards are dead.Tries websites liike shopjimmy.com,Ebay.com to buy these refurbishes 1 or 2 long LCD inverter boards for the replacement.
Jul 17, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony TV LCD screen blurred down one side when switched on and then after warm up appears to fix itself.
Mar 24, 2010 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
I have a sony Bravia KDL-52W3000 LCD tv. Approx.
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
Nov 26, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Apr 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony KDL-50R550A 50" LED TV 1920x1080, 240 Hz, HDTV, 3D Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
