Question about Sharp R90GC Electric Single Oven
How can i be sure that the f7 error in my ge built in over requires a key pad replacement.
    President:
  • 744 Answers
Hello, I assume since you are asking about the touchpad you had an error code or the appliance just stopped working. The way to be sure the touchpad is at fault is to switch the power off and then remove the ribbon/wire harness from the touchpad to the EOC (Electronic oven control). turn the power back on. Leave for 24 hours if the error comes back it's going to be the EOC if the error does not come back then you have a bad touchpad. Hope this helps, If you have any other questions or concerns please feel free to comment again and thanks for using fixya! Good Luck. Mike
Posted on Jul 20, 2009
I keep getting a message F7
Error F7 is related to function keys it might be shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the oven control board (ERC).
Nov 17, 2010 | GE Ovens
I have a GE Range model JBP85. I have an error code F7. It appears the clock key is stuck. Is there any way to unstick this or any other key? The key pad is expensive to replace.
Hi, Error F7 on your oven means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC).
Oct 23, 2010 | GE JTP15 Electric Single Oven
I have a GE built in oven Model JKS05B0WPBB and getting an F7 blinking light. Can you give me some guidance? Thanks.
Hi.
F7 on GE ovens means that there is a poor contact to keypad detected. When this happens the problem is either keypad or control panel.
Problem is fixed testing keypad and control assembly and replacing the faulty part.
Here the procedure to test the parts:
Hold down the CLEAR/OFF button on pad.
Disconnect the ribbon cable connecting control panel to pad and wait about one or two minutes to see if the code comes back.
If the code comes back, then you likely need to replace control assembly.
If the code does not re-appear on display, then the problem is with the key pad. In that case replace the key pad.
The procedure is only indicative. In case of faulty control assembly procedure may not be a definitive test. In that case replace the control pad first.
To find parts and diagrams for your appliance, enter the model number in the links listed below:
Where do I find parts and diagrams?
Aug 10, 2010 | GE Ovens
Have JKP86 oven and the controls on the oven do not work. Get an F7 error code
The F7 error code on GE ovens indicates either the control has detected one of the key pads on the interface/control is stuck or the clock ( ERC ) itself is faulty.
The first step in determining if it's simply a stuck key pad is to push the cancel/off key ( If you haven't already ). If that fails to clear the error try to shut off the 40amp breaker to the range at the service panel, leave it off for several minutes and upon resetting it the error will either return or the issue was a stuck key pad and you're good to go.
If the error does return after turning the power back on, you'll likely require a new ERC ( clock/timer ) unfortunately.
Hope this was helpful in moving you forward. Thank's for visiting "fixya" today and good luck.
Please take a moment and rate the information provided here accordingly.
macmarkus :)
Apr 10, 2010 | GE JKP86 Electric Double Oven
F7 dC
Well first of all you determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
This error code F7 means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC)......
Post comments for more help or information........
Good Luck!!
Mar 26, 2010 | GE Ovens
My oven has an error code of F7. what is the problem?
Hello there
Any time that you get the f7 error this means
F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
repair or replace keypad switxh or erc circuit
Mar 23, 2010 | GE PT956CMCC Profile 30" Built-In Double...
We get a F7 error code on our model JT910SA3SS
F 7 code is an most G E ranges . is stuck key on pad . some of these can be unstuck but if hi heat caused the pad is warped and not repairable . turn off power disconnect the key pad from the clock and if code goes away key pad is at fault if it does not the eoc is at fault . and you will have to replace the clock . **** hope this helps . feed bk pls .
Dec 26, 2009 | Ovens
F7 error built-in oven
F7 is a stuck keypad error. Sometimes you can push every pad at random several times each to unstick the keypad.
If that fails the ERC(clock) will have to be replaced.
Dec 04, 2009 | GE 30" Built-In Single Electric Wall Oven...
Error code F7
your problem is with the EOC (Electronic oven control) or touch pad if it is seperate from the control...if the touch pad is seperate...unplug range - access the control panel - remove the wiring/tape wire from touchpad to EOC...plug range back in...leave over night...if f7 code comes back it's the EOC...if the error code clears it's the touchpad...replace the part with the problem...if touchpad built into EOC replace the EOC. Hope this helps...if you have any other questions please feel free to comment again.
Jul 06, 2009 | GE Ovens
F7 beeping an cannot stop it... any solutions?
HI, if this error code cannot be canceled, this will confirm a touch pad issue. the membrane is damaged and, this will require you to replace the ERC.
Replacing the Electronic oven control will fix this issue.
Mar 29, 2009 | GE JKS05 Electric Single Oven
Sharp R90GC Electric Single Oven Logo
Top Sharp Ovens Experts
JOHN LAPIER
Stan Ford
Tom Chichester
Are you a Sharp Oven Expert? Answer questions, earn points and help others
