Question about Toshiba Televison & Video
I need the schematic diagram for the tuner in the toshiba sd-v393su1 dvd/vcr deck
    Top Expert:
  • Toshiba Master
  • 40,234 Answers
Request the diagram directly from Toshiba.
Posted on Dec 16, 2016
How Can I record a TV program using my SD-V295KU. Where Can I chose the chanel number? Can You hepl me please? This is a DVD Video Player & Video Cassette Recorder.
The SD-V295KU has no tuner. You will need to connect it to a set top tuner, a cable or satellite receiver box. One of the digital-to-analog converters would work for OTA programs from a digital station. The basic ones that were available with the government coupon give SD output; this is sufficient since composite video is limited to SD.
Then connect the composite (audio and video) out from that box to the DVD/VCR composite in (the rightmost jacks). Then set the channel on the box and record content on Line 1 (Press Input Select on the DVD/VCR's remote to get to that input after you set the recording speed.)
Most TVs do not have a composite out option so the tuner in the TV can't be used to feed the program to the DVD/VCR.
I wish that I had better news for you.
Jun 04, 2011 | Televison & Video
Now that we are on digital will the SD-37VB dvd vcr recorder work or do I have to alter a setting to make this happen
If the unit has a built in analogue tuner, the unit itself will still operate as normal, but without the built in analogue channels - to record a TV show, you would need to connect an external set top box to it (SD or HD - or both).
In other words, apart from a separate set top box, if required, there should be no need to change any of the unit's settings if it works as is. I do not believe this model has a built-in digital (DVB) tuner.
Apr 13, 2011 | Toshiba SD37VB DVD Player / VCR Combo
Can I connect my Toshiba dvd-player sd-770sr to a laptop and then make my laptop screen seen on my older tv that is connected with scart to the dvd player?
you can connect you dvd player to your laptop but you need a usb tuner that will accept video and audio input such as products made from razzle as i never heard of a laptop that has an input and scart has an issue connecting dvd/vcr's to tvs because of synchronizing the composite video signal (which is companded into red, green, and blue) from the VCR with the RGB signals needed by the monitor.
Hope that helps answer your problem let me know
Mar 17, 2011 | Toshiba SD770
How do i record from a vcr tape to a dvd on a sansui dual deck vcr dvd recorder?
If it is a combination VCR/DVD player,they usually can't do it.If you get a separate VCR player from a friend or neighbor,you can connect the VCR output to a cable box input,cable box output into DVD input,or if the DVD recorder has a digital tuner you can plug the VCR output player straight into the input of the DVD recorder.DVD recorders REQUIRE some form of digital input.That is why you need to route a VCR player through a cable box or the DVD recorder needs a digital tuner.If you are not sure if your recorder has a digital tuner,call sansui,they will know.I tried to find Sansui home and I found everything BUT DVD/VCR.If you have a manual it will be in there,or it may have a phone number on a label(back or bottom probably)of the unit.Good luck!Greg If you want to send me your model number,I will research it further too.It is up to you.
Aug 06, 2010 | Televison & Video
Need missing owner's manual; cannot find on Toshiba's site
The manual can be found here:
Apr 26, 2009 | Toshiba SD-V295
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
Need an RCA Adapter for a TOSHIBA D-VR610KU
If the RF Modulator will convert a coaxial signal to an RCA output signal, fine however, you still need a tuner to select the channel on the TV you want to record. This unit is primarily for dubbing or copying DVD to VCR or VCR to DVD. There is no tuner in the unit to get the cable signal. Try hooking up an additional VCR, that probably has a tuner in it and use the RCA out of the 2nd unit to the RCA in of the Toshiba. Hook the coax to the input coax jack of the 2nd then RCA out to RCA in of the Toshiba. Choose what channell you want to record on the 2nd unit. You may have to choose Auxillary mode on the toshiba the press instant record on the Toshiba. Again, this unit is a Player or Dubber. Not designed to record TV shows without an external tuner. I hope this helps. If you use a 2nd VCR just to get the TV Signal, you won't need the modulator.
Jan 21, 2009 | Toshiba DVR610 DVD Recorder/VCR
Digital TV
It does have a tuner built into it.
It is not a hd or digital tuner.
<A href="">
Feb 23, 2008 | Panasonic PV-D4752 DVD Player / VCR Combo
Televison & Video Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
