Question about LG Televison & Video
How to replace a water valve on LG WT120cwcw
Flat top
    Sergeant:
  • LG Expert
  • 448 Answers
Remove top control remove hoses mark were they go same with wires remember to unplug your machine b4 working on it
Posted on Dec 22, 2016
Washing machine keeps filling with water even when washing machine off. can hear the water coming through the drawer at top and fills into drum. had to out cold water valve off
You will need to replace the inlet valve inside the washing machine. It is stuck in the open position. It's a fairly easy to replace. you will just have to unscrew the top[ in the back and lift the lid to access.
May 28, 2011 | LG Washing Machines
Manual for LG wd-8016c . cold water is not going into machine
If you have cold water pressure to the machine and the valve filter is clear you probably have a failed cold water inlet valve. Replacing the inlet valve unit should fix the problem....Not unusual. Not a big job........Good luck....Nomess
May 28, 2010 | LG WFT1071TP Top Load Washer
Faulty water valve on LG WD-12320rd washer. Code FE. can I fix this I am not near service center.
FE means Fill Error. If you unplug the machine and it still fills, and the only way to stop the filling is to turn off the valves supplying the water to the fill hose(s), then you need to replace a fill valve. It is best to figure out which one by turning one off at a time while the machine is in that FE condition. There is a separate hot and cold valve. (they are the part that the hose screws onto on the machine.) To replace valve, cover comes off machine by removing two screws at the back of the top. (not the two which go into the top, the ones just below them) Then, standing in front of the machine, use the palms of your hands to give the top a sharp push to the rear to slide the top back about two inches. Then lift the top off.
Apr 08, 2010 | LG WM3431 Front Load Washer / Dryer
The electronic cold water inlet valves at the top of the machine are leaking. My manual does not list the part and i need to replace it. I dont know the correct part name or number
Water Inlet Valve Replacement Procedure
Cold water inlet valve assembly: Part # 5221ER1003A
Hot water inlet valve: Part # 5220FR2006H
  1. Safety first. Unplug the machine.
  2. Close the water supply valve.
  3. Remove the cold water fill hose and drain the residual water into a pan or bucket.
  4. Remove the two screws on the back of the top panel securing it to the cabinet.
  5. Slide the top panel to the back of the machine and lift it off the cabinet.
  6. Disconnect the wiring harness connectors from the valves. Mark the connectors to make sure you reconnect them to the right valve.
  7. Unscrew the valve assembly from the cabinet and pull it out.
  8. Loosen the hose clamps and remove the hoses from valve assembly.
  9. Connect the hoses to the new valve assembly. Reinstall the valve assembly and the top panel in reverse of the steps above.
  10. Reconnect the fill hose and open the water supply valve.
Jan 26, 2010 | LG WM-2277HW Front Load Washer
LG wm2077cw washing machine: cold water won't shut off.
You probably have a bad cold water valve. Remove the screws ot the top cover after unplugging unit These screws are on the back at the top. Slide the cover back and up. Trace your cold water line to the valve and this is the one that is bad. It is held on by screws from the back. Remove the old and replace with the new.
Jan 24, 2010 | LG WM2077CW Laundry XL Front Load...
LG makes a high pitched sound during water add cycle
Hello.
The high pitched sound is a definite sign that the water valve in use is failing. The squeal is from a restricted water flow through the valve because it is not opening all the way. You will need to choose cold or hot to narrow down which valve is bad and replace that one.
Jul 15, 2009 | Maytag PAV2300 Top Load Washer
Flashing FE and wont stop filling with water
FE means Fill Error, but you already figured that out. If you unplug the machine and it still fills, and the only way to stop the filling is to turn off the valves supplying the water to the fill hose(s), then you need to replace a fill valve. It is best to figure out which one by turning one off at a time while the machine is in that FE condition. There is a separate hot and cold valve. (they are the part that the hose screws onto on the machine.) To replace valve, cover comes off machine by removing two screws at the back of the top. (not the two which go into the top, the ones just below them) Then, standing in front of the machine, use the palms of your hands to give the top a sharp push to the rear to slide the top back about two inches. Then lift the top off.
May 31, 2009 | LG Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
FE code water overfills due to faulty water valve
Water valve is stuck open and needs to be replaced.  The best way to check if the water valve is the problem is to remove the top cover, run the machine to get the water running.  While the water is filling, remove the connector to the water valve that is filling.  If the water continues to run without the connector, the valve needs to be replaced.  If the water stops flowing when disconnected, you may have a control board problem and will need it to be replaced.
Jan 08, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Televison & Video Logo
23 people viewed this question
Computer Repairing
Computer Repairing
