Question about Crosley Washing Machines
What cause a Crosley front load wash not to spin or wash the clothes
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
SOURCE: GE front load washer (clothes)
THANK YOU. for those of you with a screw driver, here are the photos on how to.
It takes a philips screw driver and 20 minutes. The white screws may not align perfectly but don't worry, just get them to go back in the hole(no harm done).
I'm going to admit it was my wife that found this fix, so now I give the step by step photos.
[IMG]http://i26.tinypic.com/23upff6.jpg[/IMG]
Small white screws (3 in total)
[IMG]http://i30.tinypic.com/69n9eh.jpg[/IMG]
cover "falls" off
[IMG]http://i29.tinypic.com/24erogl.jpg[/IMG]
Unscrew the lint trap (turn to the left)return when clean to hand tight
[IMG]http://i32.tinypic.com/9uralw.jpg[/IMG]
Bob's your uncle and a freebee for CMKX'rs.
Hub and wife team.
Posted on Apr 15, 2008
  • 20 Answers
SOURCE: washer will not spin, will not spin in any spin cycle
Your water pump is clogged
Posted on Feb 10, 2009
kvhappliance
  • 218 Answers
SOURCE: F20 ERROR ON MAYTAG FRONT LOAD WASHER
Is it filling with water?
Posted on Mar 20, 2010
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
We purchased a Crosley Top loading high capacity washer several months ago. Why are ALL the clothes, regardless of fiber content, wrinkled when they come out of the washer? It does not matter the size
That's a normal result of the spin cycle which wrings the excess moisture out of the fabrics. The wrinkles should disappear, or be significantly reduced, after running them through a clothes dryer, or hanging them properly for line drying.
However, more wrinkles will remain if you allow the damp clothes to remain in the washer too long before drying.
Jan 02, 2015 | Crosley Washing Machines
Hi my washer moter works but spin cycle is not working Every thing else is O. K Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 29, 2011 | Crosley CAWC529JQ Top Load Washer
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Sep 02, 2009 | Crosley CW6000 Front Load Washer
Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Apr 02, 2009 | Crosley CW5000 Front Load Washer
Owners Manuals
Where is the filter for my washing machine locate it??Hot point top load..It keeps leaving white stuff all over my dark clothes.
Jun 25, 2008 | Crosley CW5000 Front Load Washer
Crosley digital front load washer
jus try to lubricate the lock n then try.... it wil work
Jun 17, 2008 | Crosley CW5000 Front Load Washer
Crosley Front Load Washing Machine
FL is a flood condition fault, too much water in unit. i would turn off water supply and try to spin water out. select spin button, should put 8 min on timer try startin that water should pump out then if not you got somethin stuck in pump (lint likely)
Feb 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Crosley caw5923mqd Top Load washer spins but leaves A LOT of water in the clothes
have you checked the pump out of the maachine
the pump may be blocked restricting water flow
if that is ok maybe you need to give the n
machine a hot wash the seals may be draging the spin down
Oct 12, 2007 | Crosley CAWC529JQ Top Load Washer
My spin cycle
does the washer have paddles on the inside of the drum if it doesnt then try putting alittle less clothing if there is too much clothing then the items tenned to get pushed together and tangle themselves up which means together they are to heavy to spin
Aug 19, 2007 | Crosley CW6000 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
