Question about Homedics Personal Humidifier
Why does my homedics humidifier shut off after 5 min?
I have the HD15 how do you clean it latly everything is covered in a chalky mist in the room?
Hello FREIDA GRAYDEN,
If you are not TOTALLY SATISFIED... and that has
the SHARPER IMAGE price tag...
(in y opinion... I would return it to SHARPER IMAGE
and us the REFUND to buy 3 to 5 equivalent units ...
(like HoMedics) for a whole lot LESS...!!
(in my opinion)).
More units... less WATER spritzing around =
HAPPY FREIDA (I think).
I sincerely believe... the "chalky" you speak of is
merely a product of the CALCIUM level in your
water... and a mist type of humidifier. Nothing
wrong with your humidifier (follow owner manual
cleaning instructions) BUT what you see is normal
Sharper Image EV HD15 Instruction Manual Page 3
THE VISIBLE "mist" Your humidifier puts out are
solid water drops... It WILL mark whatever it
lands on...
I think there ARE things you could try...
Obviously turning down the humidifier to
merely moist... rather than SPRITZING water
on everything (solid/visible).
Spread the load between multiple machines
(as described above)
Perhaps...filtered water might help
Dietary CALCIUM is a very good thing... and humidity
is much more warm and comfortable... but the combination
is going to give you those SAME results...
But at those SHARPER IMAGE prices I would
expect YOU to be TOTALLY SATISFIED.
Carnac the Magnificent
https://www.amazon.com/HoMedics-Cool-Mist-Ultrasonic-Humidifier/dp/B00EW1QJPS/ref=pd_sbs_201_2?_encoding=UTF8&pd_rd_i=B00EW1QJPS&pd_rd_r=S79PF7TS0FVV4D24Y2GP&pd_rd_w=jrPo2&pd_rd_wg=POkzf&psc=1&refRID=S79PF7TS0FVV4D24Y2GP
Jan 11, 2018 | Humidifiers
Instruction manual for Homedics humidifier model UHE-WM62GY?
Try Googling (homedics)(UHE-WM62GY)(manual) without parens.
How to clean homed is humidifier
Hello, Mary -
This is the link to the PDF document with the Instruction Manual for the Homedics Humidifier model UHE-CM45:
https://www.homedics.com/media/documents/homedics/instructionbooks/UHE-CM45_IB.pdf
Cleaning instructions start on Page 9 of the instructions.
You can download and save the instructions as well as print them, if you wish.
Best wishes.
Jan 08, 2018 | Humidifiers
Need directions for homedic ultasonic humidifier
http://www.homedics.com/cool-mist-ultrasonic-humidifier-3574.html
Dec 08, 2017 | Humidifiers
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
My homedic s humidifier is leaking.I turn it on in the evening and next morning I see it in a puddle of water.Happens every time.
Chances are it is just condensation not leakage if it's only wet when its running. Nothing you can do except put a towel under it.
Dec 01, 2014 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Humidifier
remove all logic circuits and make your own remote of ultrasonic generator
Feb 28, 2008 | Humidifiers
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Homedics Personal Humidifier Logo
149 people viewed this question
Top Homedics Humidifiers Experts
Paul Carew
Dennis
Are you a Homedics Humidifier Expert? Answer questions, earn points and help others
