Question about Garden
Where is the carb on a 26 inch craftsman snow blower
I have a craftsman 26 inch snow blower where is the carb located. starts but stalls blew snow a little bit then stalled out. tom
  • 3 Answers
SOURCE: i have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Posted on Feb 22, 2009
SOURCE: craftsman 32cc blower stalls
Your carb is leaning out, causing the thing to die. Try adjusting the mixture screw (out) to richen the mixture. If there is a cap, you can pull it off to go richer. If that doesn't work, either the filter/pickup is plugged, the fuel line is kinked/smashed, or the carb needs to come apart to be cleaned.
Posted on Jun 12, 2009
  • 173 Answers
SOURCE: Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Posted on Aug 01, 2009
  • 430 Answers
rebuild the carb.
Posted on Nov 30, 2009
  • 15 Answers
SOURCE: Craftsman 19.5 HP Briggs and Stratton engine.
disconnect fuel line from carb and crank engine. NO FUEL-check in-line fuel filter, kinked line, trash or water in bottom of fuel tank. FUEL- gas is stale, has water in it, or carb has sediment in bowl, bottom jet or idle jet.or float could be stuck shut.
Posted on Feb 10, 2010
Remove impel assy.
Hi Shirleu,
Here is the Craftsman's Manual for your model to fer too. The link is Craftsman 536 886190 26 Inch Snow Blower Owners Manual .
I am going to put you towards a video. By which. You will find a multitude of sears opportunities to view for your understanding at this link. These days . We all like to watch and see be fore we do.
Follow. Craftsman Murray Snow Blower Belt and Friction Wheel Replacement
There is so much other content to choose from on the side bars; I even became levitating.
Fare. Well.
Dec 12, 2014 | Garden
Snow thrower backfires and stalls
sounds like carb needs cleaning or plug changed
id do both
Jan 30, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Snow thrower
you need to thin out your mixture on the carb. should solve this.
Auger shaft jammed
put it in neutral pry it backwords , bad rubber sweep making it stick or you blew it up , gas mix ?
Jan 25, 2014 | Toro Power Max HD 926 OXE 26 inch 265cc...
Craftsman snowblower
does it have a fuel shut off valve on it , make sure the tank hose to carb is clear ,take the carb bowl off to see if the float and needle and seat are not sticking
Jan 22, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
My snow blower does not start
warm up to thaw any water that may be frozen in carb
check gas be sure you have some in it
pull bottom of carb off inspect for water or dirt
put back together try to start
Jan 03, 2014 | Cub Cadet Snow Blowers. 26 in. Two-Stage...
Craftsman snow blower stalls
X plug and carb adj.
Feb 14, 2013 | Garden
Starts and runs, stalls out. rebuilt carb same problem??
at what point does it stall out? when you try to go to full throttle or while it is just idling?
Feb 13, 2013 | Craftsman Snow Blower / Snowblower Bottom...
Craftsman snow thrower
bad gas any or all of these
bad plug
carb dirty
kill switch on
Oct 16, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
