Question about Sewing Machines
The thread is loose at bottom I'm using t-shirt material needle # 14
  • Sewing Machines Master
  • 12,267 Answers
First, a #14 needle is probably too large for t-shirt fabric. Also, be sure to use a ball-point needle for knits. This link will help you determine which needles to use when:
All About Needles
When you thread the upper thread, be sure to ALWAYS RAISE the presser foot so the thread seats completely in the tension disk. Start off with the tension set midway between high & low numbers. Then, tweak it for your particular machine. The tension is correct when the upper and bobbin threads meet in the middle of the fabric. HOWEVER, even if the tension is correct on t-shirt fabric, you will probably need to alter the tension when you decide to sew denim or chiffon. The upper tension is not meant to be static and needs to change based on your project.
If you think the upper tension is set high and still is not pulling the bobbin thread up enough, you may need to tighten the bobbin tension. BUT, that is a big decision because it is easy to get it way out of kilter. Always mark the screw notch position on the bobbin case with nail polish before making any adjustments. That way, you can always return it to the beginning point if your adjustments are off. AND, remember, turn only 1/8th of a turn at a time. Bobbin adjustments are tiny!
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
How to Adjust Sewing Machine Tension on Craftsy
Posted on Dec 16, 2016
    Top Expert:
  • 8,302 Answers
The bottom feet keep catching my thread and stopping
try increasing the needle thread tension as what you indicate is bunching under the material from a needle thread with a too loose tension
Jul 17, 2016 | Sewing Machines
Need to now where to put tentions to sew sweat pants.
use a couple of pieces of waste material the same as the sweat pants material and sew about an inch long
adjust the needle tension and do it again
repeat the exercise until the top and bottom thread joint at the middle of the two pieces of the material
tension settings on the machine are a loose guide as the thread thickness, material thickness and needle size all have a bearing in the tensions of the thread
so practice and adjust prior to sewing is the way to go
Nov 07, 2015 | Sewing Machines
I folded over a terry cloth towel and now my machine isn't working right?
The thread is incorrect for material.
: or incorrect size needle or it is bent.
:Not threaded correctly.
Thread tangled around the spool holder.
: Thread too thick for needle or too thin.
Hope one of these helps.
Feb 10, 2015 | Kenmore Sewing Machines
Thread in bobbin assembly catching.
Could bee a few things, need a size 14/16 in needles. LONG stitch length. Also make sure you the threads in the top tensions correctly ie: one thread in each disc.
Aug 16, 2014 | Sewing Machines
Needle size for singer 3014
Your machine takes standard sewing machine needles, available from quite a few manufacturers like Organ, Schmetz and Singer. I have even seen them for sale in drugstores! Most people use #11, #12, or #14 needles--the higher the number, the larger the needle, and the thicker the material. In addition, Sharps are used for all woven fabrics like cotton and wool; ball point needles are used for things like t-shirts and other knit fabrics. Home sewing machine needles range from #8 to about #18. For instance, you would probably use a #14 or #16 needle for Jeans, although for those, there are also specialty Jeans needles you can also use.
Jun 11, 2014 | Singer Sewing Machines
I have a designer SE it wont stitch tee/shirt material it misses stitches
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Feb 01, 2013 | Sewing Machines
The top thread just hangs and knots on bottom of material
try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Feb 20, 2012 | Sewing Machines
Sears Kenmore Sewing machine model 15358 Just got this machine brand new yesterday. I've gone through the manual very carefully to make sure the machine is threaded properly. It's very similiar to my old...
The tensions must match ie. top tension =bottom tension. If the material is not sewn together tightly, that means the tensions are mismatched. Sewing machines will sew whenever the top and bottom tensions are equal (be it very tight or very loose).
We usually advise the customer to not touch the bobbin case tension. When that is not changed, all tension adjustments can be made from the top tension above the needle.
It appears that one of the two tensions (top or bottom) is much tighter then the other. I would reset the tensions to how they came, if you are unfamiliar with sewing machines this may take a little bit of experimenting until you get it back to a standard quality stitch.
The other option would be bring it to a sewing tech. A good mechanic should be able to adjust the machine and your tensions to your fabric (and recommend needle size for your thread/materials) in about an hour.
Apr 15, 2009 | Kenmore 15358
Singer solid state-bobbin part
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine. Also use a ball-point needle on t shirt material. Good luck!
Nov 02, 2008 | Singer 5050 Mechanical Sewing Machine
Singer Simple 3116
Your problem is a simple one.Jamming is due to thread getting trapped on the bobbin holder.All you need to do is to unscrew two screws holding the the bobbin holder clean the same and reasseble it.your problem will be solved.N.Govindarajan
Jun 09, 2008 | Singer 3116 Simple
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
