Question about LG Washing Machines
I am visiting and tuned on the LG front loader on cotton cycle. It is still wasting after an hour! How long will this go on. Model WD - 8013F
    Sergeant:
  • LG Expert
  • 448 Answers
Depending on size of load need more info water temp can be a issue
Posted on Dec 22, 2016
2 Suggested Answers
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
I had same problem, the bowl is supported by (2) large springs from the top & two telescoping shock absorbers underneath.
I inverted the machine, found a large hollow retaining plastic bolt had falled out of the shock absorber,causing the bowl to be out of balance & the drive belt to be missaligned.
I reinstated the plastic retaining pin/bolt then tried the machine again.
Now the damn thing refuses to wash or spin.
I'm not happy.
Posted on Nov 06, 2008
Model WD-8013F. Why does it continue filling after wash cycle should start?
water level sensor may be faulty, or the air tube that works in conjuction with the sensor may be plugged. check out repairclinic.com or appliancepartspros.com for videos on this issue and fixes.
Jul 17, 2015 | LG Washing Machines
Lg 7.5 WD-8013F had sparks and stopped working
Where do sparks come from. Motor is in back.
Mar 10, 2017 | LG WD-80130F
My Mom is 90 yrs old and lost her machine instructions. The model is front loader WD 80250 NP ( now 4 years old). Can I down load the manual? My other question is: On the Cotton cycle does the programme...
Home Depot Sales Associate-
You can find the manual for the product here.
http://www.lg.com/levant_en/support/product/support-product-profile.jsp?customerModelCode=WD-80250NP&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-80250NP&initialTab=documents&targetPage=support-product-profile
The unit is designed to only operate properly with a hot and cold faucet connection. The exception is if it has a cold wash cycle and you are operating it on such. (that model should not) Also, once you set the cycle, you should not manually interrupt the cycle to change to the desired portion of the cycle. Front load wash units take longer to run due to the usage of less water. They also need high efficiency detergents to operate properly and cannot be overfilled with detergent.
Your description of a soap lather sounds like you are using the wrong detergent and in the wrong quantity. HE only.
Mar 20, 2011 | LG Washing Machines
LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Mar 29, 2008 | Washing Machines
hi all you poor owners of this heap of junk, i have one too with the same problems, the shaking and moving around the bathroom was stopped by welding a 1/2 inch long piece of 1 &1/2 inch dia pipe to a 2 inch square flat plate of steel then putting double sided sticky tape beetween the plate and the floor
where you want the front rubber legs to sit, this stops it from running around the floor but it still needs to adjusted to have the
same on the front two legs to stop the shaking.by leaning the machine back a bit also helps to stop it leaking so bad while filling, it is only from the condersation from the hot water going in and the poor design of the soap drawer not allowing the water to run back into the washer which can be fixed by cutting the lip off
the bottom wher the drawer slides in then running a bead of silcone in the crack between the front cover and the inside piece
then another one on the front edge to run the water back into the washer. hpoe this helps. bryan.
Dec 01, 2007 | Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
