Question about GE Home Security
Hi, i have a ge simon xt alarm... i want to disconect one of the wont let me do that...what do i do?
SOURCE: Sensor alarm notice on GE Simon 3 system
Most likely it is remembering a alarm at that station. If you enter your alarm code following the "status", it will clear it. (That's how mine works)
Posted on Jan 19, 2009
  • 4 Answers
SOURCE: GE Simon XT panel lights window, door and motion indicators
The system is working as designed. If you arm both doors/windows and motions, but you DON'T exit the premises during the exit delay, the system will "downgrade" its arming to doors/windows only. The assumption is that you haven't actually left the premises and are at risk of creating fale alarms. This behavior can be disabled in System Configuration (though it may require the dealer access code to do it).
Try opening and closing a sensored external door (even if you don't go outside) during the delay after arming doors+motion and see if the motions don't stay active.
Posted on Jul 29, 2009
  • 7 Answers
SOURCE: How do I change the battery in the GE Simon XT
If your system is monitored call the central station first and tell them you are working on it. Then push down on release tab in top center to fold down the front face. Nest step is to use a small flat blade screw driver to push in and release the tab again in the top center and the unit will fold down towards you, hold on to it and you will see the battery compartment. Follow the red and black wires to the battery. Some units have a plastic lid over the battery that requires you to remove to small phillips screws to remove battery.
Posted on Feb 22, 2010
  • 74 Answers
SOURCE: GE Simon XT how do I reset the code
You neet to reset the system to factory defaults. Contact me and I can go through it for you.
Posted on Aug 23, 2010
  • 11800 Answers
SOURCE: GE simon XT alarm is going off, how do I get it to
This is the install manual for your system
Use it to locate the battery (in the main unit) and the power supply wire - disconnect both.
If you later will want to reuse it you should read the user manual on how to program it
Posted on Sep 07, 2011
I need to reset the alarm on my GE personal security window or door alarm
press the "status" button. If it is a Simon XT , press "disarm" then "status"
Mar 02, 2017 | GE Home Security
Hello. there seems to be a beeping noise coming from the control box itself and it says to check status, but i'm afraid to push anything. thank you
Troubleshooting a GE Simon XT: Clear Errors and Alerts ...
? 3:06
Oct 3, 2011 - Uploaded by LiveWatch Security
Troubleshooting a GE Simon XT: Clear Errors and Alerts -Wireless Home Security ... Many times the Simon XT panel willbeep to indicate there is something ... How do you turn off the warning beep when you turn on alarm? I find it very useless and annoying. Can't seem to find a way to turn that feature off.
My Simon XT is beeping every 4 hours. How can I stop it ...
Aug 28, 2011 - If your panel has been beeping throughout the day and you want to turn off ... Scroll down on the Simon XT until you see "System Programming".Missing: control ‎hello ‎control ‎box
Jan 11, 2016 | GE Security Simon Xt Wireless Control...
Hi there, i have a Simon XT alarm system and i want to delete a sensor or reinstall it - i took it off the window when replacing them and now th system keeps bleeping to tell me it's been tampered
Try these 2 sites:
Jan 15, 2013 | GE Simon XT Wireless Home Security System
System says low battery ... how do I open it to replace batteries...very confusing!
There are two tabs (and possibly a screw) on the top of the Simon XT panel. Remove srew (if installed) and press the two tabs, pulling forward. Front part of panel is hinged and will rock forward. Battery is located behind front half. It is a 6 volt 1.2 Amp Hour lead acid battery.
You must completely downpower the Simon XT (wall plug in and battery) then replace with new battery first, then reconnect wall power. Close the front panel and snap it closedand replace the screw (if it was installed).You will need to set the time on the panel, following the instructions in the users manual.
Jan 05, 2011 | GE Security Simon Xt Wireless Control...
How do I replace the battery in my Simon XT security system
Here is a very easy to follow video tutorial that may help you.
You can get a replacement battery from here
Simon XT GE Security Security Alarm Battery 6V 1 2AH
Mar 08, 2009 | GE Home Security
Programing 1st and 2nd numbers on the Simon XT home alarm
Try entering the programming mode with the dealer code, not the master. It's 4321 by default.
Jan 29, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon XT Home Alarm
john copy and past the likk for the installation and programing manual.
Dec 30, 2008 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
49 people viewed this question
Top GE Home Security Experts
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
