Question about Maytag Dishwashers
Maytag dish washer model mdb6709awb1 runs on only normal and heated dry no matter which buttons i press
Have tried the high temp wash heated dry reset twice. goes thru the diagnostics but doesn't change anything
    Top Expert:
  • Maytag Master
  • 75,051 Answers
You will need to replace the control board most likely.
Posted on Dec 15, 2016
How to reset Kenmore Elite 665-16572202 Dishwasher...clean light blinks 7 times pauses then repeats. My model does not have a Heated Dry button it has an Air Dry button.
Here's the key sequence(s) to use, depending on how your keys are labeled:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
This will start the diagnostic cycle. Let the dishwasher run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. Please note, that this clears the error, but if you haven't found the cause (water-not-heating error), the condition will come right back the next time you run the dishwasher.
Jan 19, 2015 | Kenmore Dishwashers
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Apr 03, 2014 | Kenmore Dishwashers
I have a Whirlpool Gold Quiet Series Plus, Model GU940SCGT3, not working. It ran a cycle, cleaned the dishes, but the water didn't drain and the "CLEAN" light is stuck on. It is now...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
CLEAN LIGHT BLINKS 7 TIMES ON KITCHEAID KUDP DISH WASHER
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Aug 08, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dish washer the clean light stays on and the dish washer wont run
Kevin
Jul 15, 2011 | Whirlpool Dishwashers
DISH WASHER NOT WORKING, ONLY CLEAN LED FLASHING
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 15, 2011 | KitchenAid KUDE60FVSS 24 in Builtin...
How to reset control panel on model 587.1517 kenmore dish washer
From what I have read elsewhere, the interrupt *may* have something to do with a thermostat circuit cutting out if the entry hot water is too high ( more than 145F) - it seems like a buggy safety feature i.e. the circuit board thinks that the water heater is overheating. The makers have apparently made changes to the control board to fix this bug but it costs serious $$$ to get a repairman in and buy the new board.
I prefer to use the reset code, and keep my water temp lower when using it.
Feb 20, 2011 | Kenmore Dishwashers
Will not run
than either replace heater sensor or element.
Give me model number pls
May 03, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
