Question about Sony STR-DB840 Receiver
I've problem getting any Sub sound from Sony STR DB840. The sub is ok and I've correct setting on my reciever with sub enabled. When performing tone test... I can hear sound from all connected speaker except from the sub.
My STR-DB840 had no sound from center channel nor sub channel, other four channels worked fine. Ended up being a faulty AK4527 DAC chip on the digital board. This little ****** has 3 serial data inputs: First one takes care of L and R, second is for rears and the third is for center and sub. No idea how a thing like this can fail, i bought the unit almost new but second-hand eight years ago and used it until now with 2 large front speakers and rears so maybe the problem was there all the time.
Swapped the data lines 2 and 3 by soldering and crossed the analog wires at the AU switch board connector so that the three front channels and sub are now okay but the rears are sacrificed. Works for my 2.1 setup though.
the AVR could still be used for 5.1 with an external decoder as the 5.1 inputs do not need the DAC.
Posted on Dec 03, 2011
    Sergeant:
    Champion:
  • 231 Answers
Make sure sub is working .Power it up , remove sub RCA jacks from receiver .Gently tap on RCA with fingers.You should here a hum when touched .You can also try audio from TAPE REC OUT .If you dont get audio .Check setting at sub .If it working okay check setting at receiver and or sub level at receiver
Posted on Jul 21, 2009
I have a Sony DH-810 reciever and 7 speakers (8 ohm) and one sub (4 ohm). I don't get any sound from my sub?
Remove power for a while and reset the amplifer, check for any error codes. If you do not have a manual please check the following link for the nearest model. Calibrate and use test tones according to the procedure mentioned in the manual and reset.
If there is no result the sub woofer amplifier is faulty , need to check within for the power supply or there can be a failure within in the driver output.
click this link:
http://www.docs.sony.com/release/HTDDW790.pdf
Oct 07, 2011 | Sony STR-DH810 Receiver
I have a sony STR-DH510 receiver and the speaker set that goes with the DAV-BC 150. i hooked up the speakers but i couldn't get the sub to output any sound. is there anything i can do to get it to work?
Hello ,you will want to go into the setup mode on the remote and make sure the subwoofer is turned on,it might be turned off .You can view the setings right on the front of the reciever as your scrolling thru speaker setting options.
Feb 08, 2011 | Sony STR-DH500 A/V Receiver
Hi, the receiver has no sound when it turned on and the display is off as well, although the functions as output, channel selector are working. Appreciate your input for the problem.
SONY STR db840
No display:
broken trace on "Digital board" ,feeding 32v from "DC board" to "Display board"
solution: make new jumper btw. "CNS2" and "CNP4" on "Digital board"
Now display OK again : )
Sep 26, 2010 | Sony STR-DB840 Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
Sound from reciever
LFE (ONE CABLE ON THE SUB TO SUB OUT ON AVR) OR stereo L/R analog cable from sub to tape in/or out on avr (depends on AVR) LFE connection the sub turns up with the AVR - the stereo cable threw tape in/out on AVR only turns up via its own onboard amp volume from AVR has no affect.
Aug 21, 2009 | Sony STR-DH700 A/V Receiver
No sub sound
Turn on the subwoofer output. There is a configuration option for all the speakers: left, center, right, surround, and sub.
Jun 13, 2009 | Sony STR-DB840 Receiver
Sub not working with amp
Connect a sub cable to the amps sub OUTPUT then to the sub input turn the volume up half way on the sub then go to the amp setup menu and make sure the sub is switched on then set the cross over to suit your speakers,if your not sure set to 80hrtz.
Hope this helps.
CABLE GUY.
Feb 24, 2009 | Sony STR-DE475 Receiver
STR-DB840 no sound in speakers
There are 4 blue relays in the unit that has solder points that will crack over time.
It´s fairly "easy" to re-solder them and viola, it´s OK again.
open the cover (unscrew and take of the hood) and locate the 4 blue relays.0cddb82.jpg Unscrew and remove the bottom service plate and locate the soldering points for the 4 relays.c0f1d35.jpg
Each relay has 6 solderings, 4 in one "groop" and 2 in one "groop" look especially at the "2-groop" these are the ones most likely to crack over time ( for me 12 years or so).3436d08.jpge6f7344.jpg
Re- solder. Best of luck //Ronnie Stockholm
Jan 27, 2009 | Sony STR-DB840 Receiver
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Sony STR-DB840 Receiver Logo
414 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
