Question about Cameras
Battery fully charged,but still will not work.What else could it be or what do you suggest.
  • 1,381 Answers
Are the terminals clean
You haven't blown a dose somewhere if you have reinstalled battery after charging
Posted on Dec 15, 2016
Testimonial: "yes checked everything and all seams ok but still does not work. thank you."
The bike dies, after a fully charged battery.
Bike has magneito (thats spelled wrong ) On line youtube veido shows how to fix that.
Apr 01, 2012 | MBK Motorcycles
Message says battery not fully charged but Icon says 100% charged
This machine is roughly 4 years and so the battery does not hold the charge like it used to. It's just suggesting that you should look into a replacement battery that will hold the charge longer than the current one which will give you more time to use the device.
May 06, 2010 | HP Pavilion dv6000z Notebook
Canon 300d flash won't fire. Pops up ok but display just reads "busy" and camera locks up. Must turn on/off to get camera working. External flash works ok.
This may sound obvious, but have you tried to make surer the battery is fully charged and then see'ing if it still does this? The reason I suggest this is that I had a similar problem and when I fully charged the battery this problem went away. I tend to keep an extra battery (fully charged) plus the charger on hand at all times.
Dec 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
Have a 1996 Taurus wagon--dead battery--got brand new battery and connected it properly and car barely turns over and wont turn enough to start--car was sitting for about three months
Was the battery checked before it was sold to you? Batteries will lose their charge over a period of time even when not hooked up. If you have a voltmeter it should read 12.8 volts on a fully charged battery.
Have you tried to boost the car with cables?
I suspect if the car was working OK 3 months ago it should start. Which leads me to suggest an undercharged battery.
Oct 30, 2009 | Ford Taurus Cars & Trucks
Goes from fully charged to almost zero charge in seconds
HI,
Please make sure the charger is working.I suggest you try replacing it with a new charge and then give it a try.The problem can also be with the battery if it is more than 2-3 yrs old.In this case the problem is with the battery.
So i suggest if the battery is more than 3 yrs old buy a new one and then test it with the old charger and if the battery is not old then replace it with a new charger and try charging the battery.
Let me know the result
Jul 02, 2009 | Samsung BlackJack II Smartphone
Ipod nano - stopped working - will not come on anymore
Do the 5 R's suggested in the user's manual first. If those fail, then the player has an internal problem and needs to be replaced.
Sep 03, 2008 | Apple iPod nano
Startup/charge issue
Sad motherboard sorry,
replace and start again
Jul 21, 2008 | HP Pavilion dv6000z Notebook
IPOD Video 30gm
Hold down on the center button while hold down on the menu button. The apple logo will appear. Your Ipod is now rebooted.
Is the new battery fully charged? Usually it takes 6 hours on a new battery.
Jun 08, 2008 | Apple iPod MA446LL/A MP3 Player
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
Laptop shuts off when unplugged, battery is fully charged
Chosenone, Even though the battery meter shows it fully charged I doubt it?s correct. Over time rechargeable batteries loose their ability to store power. How long depends on the battery manufacturer and how well you treat it but you can consider yourself fortunate if your battery lasts three or four years. Beware of people who suggest you take apart your batter to bypass the safeties or replace old battery cells. Defective or improperly handled batteries can overheat and cause fires when you least expect them. Let us know if you have any more questions and please don?t forget to rate this post.
Feb 23, 2007 | Compaq Presario 1200 Notebook
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
