Question about Speed Queen Washing Machines
I have speed queen swt521la coin operated washer and need to change the amount it costs per load. How do I do this?
I am able to get into the program location, but have no clue what it means and haven't found what buttons to push to get to a place to change the amount. There are only 6 buttons on the panel. (Norm, perm press, delicate and hot, warm, and cold.)
SOURCE: whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Posted on Feb 15, 2008
SOURCE: Speed Queen doesn't agitate.
can i see solution that ziobob got on nov.08 2008
Posted on Dec 02, 2008
gdmisp
  • 66 Answers
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Posted on Jan 16, 2009
onthejob5130
  • 640 Answers
SOURCE: water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Posted on Jan 17, 2009
SOURCE: I get a check water tap error 2 to 4 times a load
I have this problem. This code is due to restriction of water flow. In my case, we have sand in our water, and I have installed a filter between the water line and the washer. When it gets clogged, the flow is restricted and the Check Water Tap message appears. Your washer has filters on the back of the washer itself that may be clogged and need cleaning (which is why I installed the water filter between the washer & water line to prevent it from getting into the washer filter). Your washer manual shows you how to check/clean them. Also, you may have low water pressure during summer months due to lawn watering in your area that could cause this lower water pressure.
Posted on Jul 01, 2009
Washer motor overheating
Check the drum for ease of rotation, bearing noise. Make sure all support springs are good and at the same position.
Nov 27, 2013 | Speed Queen SWT921 Top Load Washer
What is the minimum amount a coin counter can count?
It really doesn't say what is the minimum but i'm not sure there is one. you just put in one coin and it counts it. The speed is what matters in counters. there are fast counters that can count around 150 coins per minute.
Apr 29, 2013 | Retail Supplies
We have coin operated washing machines is there a sheet to show us how to change the price
http://www.pwslaundry.com/c-295851.4-commercial-speed-queen-swfx71n3000-front-load-washer-parts-for-repair-service.html
You want the one that says Programming...
Dec 31, 2012 | Speed Queen Swfx71_N3000 Commercial...
Speed Queen Front Load Coin operated # SWFT71.. The coin changer keeps getting stuck. Any ideas on how to resolve this?? How do I remove the coin changer from inside the machine??
I have not fixed any of these front loaders for a while, but the top cover should come off (usually with a key), which will give you access to the coin mechanism and timer. There you usually need a 5/16 wrench or a flat screwdriver to remove the screw at the top of the mechanism.
Dec 04, 2012 | Speed Queen SWFT71 27" Coin Operated...
How to break speed queen coin machine
why do you want to brake your washer for in the first place any way
Nov 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
I have an old speed Queen coin operated dryer and I would like to remove the coin function. Can this be doneMachine detail on request.
you can get it to run by installing coin plugs in the slide are assembly or leave the top lock panel open and push the spring arm before each load for personal use.
May 22, 2009 | Dryers
Whirlpool coin operated washer and dryer
Sep 06, 2007 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
