Question about Linksys WCG200 Wireless Cable Modem 54G Gateway with 4 Port Switch Router (NETWLSWCG200)
I have a problem I just bought GE 2.4 GHZ phone
It kicks me out onf my router a Belkin 54 Any Help?
  • 14 Answers
I'm not sure if your phone has a channel selection or not, but I know your router does. This issue happens because both wireless internet and cordless phones operate on the same frequency. To change your wireless channel you need to go to your router settings which should be at 192.168.2.1 for a belkin router. To get here you simply type that number where you would normally type a web address in your browser. You enter the username and password and go to wireless settings. Under there you should see something along the lines of channel. The most common channels are 6 and 10, if your router is already on one of these, try another channel. Just keep doing this until you find a channel that your phone is not using and your router should work just fine now.
Posted on Jul 20, 2009
Router signal dropped freqvently
do you have cordless phones running on 2.4 Ghz ?
try changing the channel number setting on the router from auto to use at least 2 channels higher than auto was using.
Jan 25, 2016 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My phones run with 2. Ghz frecuency so when I used my inalambric phones get disconnected from the web, how can I solve this problem I have a router model F5D 7230-4
On all wireless routers there are channel settings. If you phone is on the same channel, you may have problems with the router. Also make sure your base station to your phone is not next to the router. Its radio waves may cause interference. First thing to try is to change the channel number for your wireless router. See the attached link for your router information and how to change the channel.
The link is: http://en-us-support.belkin.com/app/answers/detail/a_id/76/q/routers
Good Luck.
Jan 30, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
What is the max download speed for a belkin g wireles route. mine seems to be limited to 2 MB
It depends on the router that you have.
If you are using a wireless G router, then the wireless speed will be 54 mbps. and if you are using N series router then the wireless speed will be more than 54 mbps.
Click here for more information about the routers
Oct 06, 2009 | Belkin Computers & Internet
Belkin router gets me kicked off internet after 2-4 days.
It's probably temporary interference between the router and your computer.
1. Regrigerator, metal filecabinet, too many walls in between, etc.
2. Also, the router is using the same frequency (2.4GHz) as:
Microwave oven, cordless phone (not cell phone), Bluetooth headset
3. Move the router if you can to a higher location, and change the direction of the antennas (point the antennas in-line with the direction of the laptop).
4. If you obtain a different router, get one that uses "N" wireless, even tho your laptop uses "G", the "N" router can get around interference.
You do not have to change your "G" laptop to "N".
Sep 28, 2009 | Belkin (F5D8231-4) Wireless Router...
Conflict between wireless router and cordless phone
you should try changing your wireless channel in the router setup.
1) log into your router.
2) go to the wireless setup page.
3) change the 'Wireless Channel' from auto to 1-11.
4) re-boot your router and re-connect to it.
5) use your cordless phone and see if the connection drops out.
6) repeat steps until you have a stable channel
good luck :)
Jan 28, 2009 | Linksys WCG200 Wireless Cable Modem 54G...
Keep getting kicked off xbox live
You should reduce the MTU of your router. You can simply call Belkin support for them to assist you on how to reduce the MTU.
Oct 26, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
When the phone rings my belkin 54g disconnects and also it pulls from the other computers.
This usually happens on cordless phones running on the same frequency (2.4 GHz). Here are some steps you can try to lessen the interference that you are getting:
1. Change the wireless channel of your router. (refer to router manual if necessary)
2. Make sure that the base station of the phone is not near the router.
Aug 16, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connecting second laptop to my Belkin Wireless G router
I don't know the model of your router this would be very helpful. Most routers have a reset button on the back of the router. This will reset your router back to factory default settings.This will reset the pasword to default usually "admin". You will need to set up your router all over again. Let me know the model and I can send you a link for installation of your router.
Jan 09, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
What is 802.11g?
802.11g is the new IEEE draft standard specification for high speed wireless LAN communications that provides for up to 54 Mbps data rate in the 2.4 GHz band. 802.11g is expected to quickly become the next mainstream wireless LAN technology in the home, office and public networks.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
