Question about Refrigerators
Thermoking rd2 locking out on rpm sesor fault. Have to clear it in guarded acess for machine to run.this code should not stop the unit.
  • 84 Answers
SOURCE: 1999 passat tdi power fault
Air mass sensor, almost never shows codes but always makes the vehicle loose power !! cheaper from vw than pattern and more reliable
Posted on Dec 24, 2008
SOURCE: Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
Posted on Jan 18, 2010
  • 27 Answers
SOURCE: reset machine
turn off machine by pressing power button hold down temperature button on front panel turn on machine while still holding temp button in quickly release the temp button and press the soil button. release the soil button and you should see a diagnostic mode on the screen there will be several sets of numbers on the screen the first set are number of wash cycles then the most recent three fault codes indicated with f1 f2 etc the last number is the software version in the computer when you can see this on the screen you will be able to reset the machine simply by turning off the power and then on again the fault code should then be gone
Posted on Dec 19, 2010
  • 395 Answers
SOURCE: Have Onan 3.6 KY propane
I am not familiar with your peice of equipment but from your description of the fault being Under Frequency it appears that generator governor is out of adjustment or the governor spring has brcome weak or broken and not allowing the engine to run at the correct speed to produce an output frequency within the allowable tolerance. Governor linkage could also be binding and not moving smoothly to respond properly to engine load conditions. Thoroughly check governor and throttle linkage for free and smooth operation and full range of movement.
Another cause could be that the engine is not getting sufficient fuel causing the governor to have the throttle wide open to try to get engine to run at its correctly governed speed but unable to do so because the engine is not developing enough horse power.
Posted on Jan 10, 2011
mercadoarvin
  • 384 Answers
SOURCE: i have a johnson jet
Welcome to Fixya.
Here's a service manual that can help you with this issue :
Johnson Jet 6000/7000 Service manual
You will find instructions and guides on how to troubleshoot problems with your treadmill.
Thanks for using Fixya.
Posted on May 31, 2011
How to clear "04" fault code on a thermoking sb 210?
It's been a while since I worked on Thermokings. But all I worked on, when the problem was fixed, the code would automatically be gone.
Aug 14, 2015 | Cars & Trucks
Location of thermostate for 1997 acura cl 3.0
The thermostat valve is located on the intake manifold either at the end of upper or lower radiator hose. The thermostat can be removed by removing the hosing which is attached by two bolts.
The presence of the thermostat can easily be determined by removing the hose pipe and inserting a center finger into the hole. (Be sure that the engine is at room temperature to avoid finger burning).
Jul 04, 2014 | 1997 Acura CL
Thermoking apu starts up then runs for a min then shuts off and shiws a code ac5 .what is this code?
If the unit starts and runs for a short period then The code will refer to either low gas or excessive gas in the system or the thermostat to control the temperature is set to close to ambient temperature. I would go for low gas from a leak in the system
Jun 22, 2014 | Cars & Trucks
Xerox workcenter7346 has fault code 009-390
009-390= IBT belt home position sensor/patch. After examing ibt belt assembly and cleaning patch and sesor, noticed that the magenta developer unit was not in proper position, this was not allowing the ibt unit to turn. Re-positioned developer unit into proper position, installed ibt unit, this cleared up the problem and machine is running fine.
Dec 11, 2012 | Xerox WorkCentreR Pro 7346 Black Toner...
Marapco generator over or under speed led how to cansel
We have this same issue with a Perkins model mp 400E here in Afghanistan. It will start up and run for about 30 seconds at its normal 50HZ 1500 rpm operating speed, then it will gradually start to slow down and shut itself off around 1350 rpm. There are 4 vertical fault lights on the control panel, and the bottom one stays red and refuses to reset. We can't figure out what is causing this fault light or the stalling engine. Any help would be greatly appreciated!
Jan 29, 2012 | Electrical Supplies
Whirlpool awm 8142 faul code f06 ja and i start it again, the new fault code f09 and the machine stops... whats wrong whit it!
F/06 error code, Drive Motor Tachometer Error
F/09 Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
~Check the drain hose and make sure it is not plugged or inked.
~Check Wire Harness connectors to the Drain Pump, Pressure Switch, and ~Central Control Unit (CCU)
~Check/Clean Drain Pump Filter of foreign objects
~Check for Drain Pump Failure
~Check the Inlet Valve for proper shut off
~Check the Pressure switch for proper operation
Nov 15, 2010 | Whirlpool AWM8143 Front Load Washer
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Calipso Clothes Washer (yea, that one...) Trouble code ''CA'' means I have to remove tiny cloth clog that faults the water pump, (I'm getting good at that one), but now I have a ''''SL''...
SUDS LOCK:
The motor controller senses a suds lock condition by analyzing the current draw on the drive
motor. If a potential suds lock is detected, the control tries up to 3 times to clean out the unit
with a mini-cycle. See Use and Care Guide for more information.
“SL” is displayed if suds are detected but the unit is unable to clean out suds. This may
indicate a bad pump, an extra heavy load, excessive detergent or excessive suds.
Press STOP/CANCEL to clear the display. MANUAL
Sep 13, 2009 | Whirlpool Washing Machines
May 30, 2009 | Indesit W 123 Front Load Washer
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
