Question about Element Televison & Video
I have a element tv ELEFT326. When the tv is turned off or "goes to sleep" it will not turn back on with either the remote or power button. I tried unpluging and repluging, that work for awhile.
SOURCE: AKAI LCT2785TA TV does not turn on
look closely at the electrolytic capacitors in the power supply. If you see any with the tops bulging out, replace them. Especially the 1000mfd caps labeled EC9, EC10, EC18, EC19, EC20
Posted on Sep 22, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
SOURCE: Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Posted on Nov 28, 2009
  • 88 Answers
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Posted on May 17, 2010
How can I program my RCA universal remote to my element tv , what button to press for the light to blink and the code to put so it can work on my tv
RCA does not have for a code Element TV. With that being said there is a work around:
Turn on your TV.Then push the code search button until the LED still ,when the LED keeps on let go the button now push and release the TV button then push and release the power button until the TV goes off, when the TV turn off stop to push the off button now push the set button the code are already set on the remote control( you might have to push the off button almost 100 times or more until you get the right code for your TV. Best of Luck
Aug 26, 2015 | RCA Televison & Video
Need code
I HOPE THIS HELPS... YOU DIDN'T GIVE US MUCH TO GO ON....
BEST WISHES!
GE Universal remote controls - instructionsHow to Program a GE Universal Remote Control
Programming a GE/Jasco Universal Remote Control is simple, requires only a few simple steps. You need to know the code of device you are programming into the remote. See the GE remote control codes page for3 digit or 4 digit GE remotes.
How to enter codes manually:
Step 1: Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
Step 2: Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
Step 4: Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
Step 5: Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
If you can't find a working code for your device or your brand is not listed try the "Code Search" method described below.
The CODE SEARCH function
Step 1: Turn on the equipment you wish to program.
Step 2: Press and hold "CODE SEARCH" or "SETUP" until the light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). The indicator light will blink once, then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
Step 4: Press and release the "POWER" button until your device turns off. Wait at least two seconds between each time you press "POWER". Note that you may have to press "POWER" up to 250 times!
Step 5: When your device turns off press the "ENTER" or "SAVE" button. The indicator light will turn off. Check other functions to see if your code is correct.
The SLEEP feature
Some GE remote controls like the RM94902, RM94904 or RM94905 have a handy "sleep feature" enabling you to turn off your TV after a preprogrammed time interval of 1 to 99 minutes. To use the sleep feature follow these steps:
1: Press and hold the "SLEEP" button until the indicator light turns on.
2: Enter the time interval in minutes using the numerical keypad. (for minutes from 1 to 9 press 0 before the actual number).
3: Leave the remote aimed at the television set.
To turn off the sleep feature, press and hold "SLEEP" until the indicator light blinks or press the "POWER" button to turn off the TV.
http://www.eliztech.com/remotes/ge-howto.php
Oct 16, 2012 | Televison & Video
Please help>>>I just bought it...When
Any set just bought or within the 1 year warranty, I would not work on because it voids the warranty call the company and try to take back and get new one.
Mar 09, 2011 | ViewSonic VT2300LED 23 in LCD TV
Tv not responding to remote or buttons on tv
Well okay!
couple of questions?
1) Is a multi remote - does it or can it control other components like a DVD player or a VHS or Cable box?
2) If it does - you may have selected one of these other components to control
NOTE: Try depressing the TV button and then try the other buttons such as channel or volume to see if it's back working.
Blessings,
A/V Guy
Nov 19, 2009 | Element Electronics FLX-2210 22 in. LCD...
Deep sleep mode on digital tv
We turn off the TV. Turned it back on using the tv turner remote that comes with the set, we push the HDMI1 mode button immediately! Must do before it goes to Deep Sleep mode. You should not use RGB mode as this will cause the problem to repeat. (Vizo HD 50") Keep trying if doesn't work the first time. You have to be ready and quick to get the mode HDMI1.
Oct 28, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Plasma vizio 50 inch goes into deep sleep mode
when turned on tv no signal comes on a few minutes later deep sleep mode and tv turns on
Sep 17, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Dell w2600 wont turn
Same problem, this is my solution. The system will start everytime if starting from power off one starts from sleep. Thus the trick is to use sleep mode to shut it down. I do not use the sleep function on the remote (it would be worth a try, let me know if you do that), but rather I have chose VGA as the entry signal ad have hooked the TV to my PC, and then I put the PC in sleep mode. The TV will do the same. When it is in sleep mode through the PC, the system cvomes back to life if the remote from the cable is used to change channels.
Feb 28, 2009 | Dell W2600 26 in. LCD Television
Deep Sleep
use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Sep 11, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Televison & Video Logo
53 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
