Question about Sharp Televison & Video
Has anyone repaired a Sharp LCD TV sub power board? I have had 2 of these blow an inverter IC. Replaced the IC but board still dead? PN is RDENCA323WJQZ
Chip is a TNY264PN. I can't find another suspect on the board that may have caused this problem.
SOURCE: LCD TV Screen repair
I have a Sharp LC52XD1E TV , It has a crack on the screen needs a new screen can it be fixed and is it worth the repair?
Posted on Jul 03, 2009
brownline45
  • 310 Answers
SOURCE: Samsung LN40A530P1F LCD TV keeps blowing main
good day. your power supply is defective. maybe the regulator is shorted. you need a qualified technician to fix your problem.
Posted on Jun 22, 2010
  • 11800 Answers
SOURCE: My TV has a 17pw26-1
No, the voltages are just fine. The fault must be either in the PMW itself or in the HT transformer - and the only way to fix that is to replace the entire inverter board.
Posted on Oct 19, 2010
Warf135
  • 137 Answers
SOURCE: I have Toshiba 15
There are a few things that can cause this fault, but the most common is the High Voltage Capacitors that feed the backlights going bad. The invertor and power supply are on the same board (Vestel 17IPS01-2)
The caps are on the power supply board and are C355 & C356 (12pf 3kv) and C354 (4.7pf 3kv). If you replace these caps it will solve the problem in 99% of cases.
If replacing these three caps do not solve the problem then it may be easier to replace the power supply board... as fixing means replacing a tiny surface mount chip with loads of legs.
WARNING: The Power Supply/Invertor board can contain LETHAL VOLTAGES even when turned off and unplugged. if you are not sure, Pay someone to do it for you!
Posted on Jan 26, 2011
budmrtn
  • 11361 Answers
SOURCE: Sharp Aquos LC-42DH77E 42" LCD TV TV appears to
The PNL-POW (LCD panel Power) and the PS-ON will be 0V until the main board send out the signal to turn them on, it is working.
Do you get backlights?
Did you check the fuses on the Inverter board? You power supply is working.
This service manual may match your chassis:
http://elektrotanya.com/?q=showresult&megnev=Sharp&megnev2=LC-42DH77E&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 01, 2011
Testimonial: "Helpful"
My LG 26LH20 turns itseld off after about 2-3 seconds. TV is a little over 1 yr old. I t happened about 2 months ago and I thought it was the cable. had cable serviced, not the problem. now it's...
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
May 09, 2011 | LG 26LH20 LCD TV
Never a problem, even last night. Now, won't turn on. Checked all connects and plugs. Unplugged, pressed 'clear'. Still just a solid red light. Sound comes through fine. Even tried all new batteries.
Tv now turn on,u have a flashing picture only a few sec. than dies have sound left only?Yes,than the tv long board call the LCD inverter board is dead.The tv have 1 or 2 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 long LCD inverter boards for the replacement.
Feb 09, 2011 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
My 32inch LCD tv screen goes black and no video shows while the sound evrythingf else works. what could be wrong? am i looking at a large cost to repair? cheers Aa
Now,tv turn on u have a picture few sec.than dies have sound left only?Yes,than those 2 tv long boards call the LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Jan 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a power supply and sound but no picture when i switch the television on i get a picture for a split second then just a black screen with sound
This problems is 100% of those 2 long LCD inverter boards in the tv sides left and right.Those 2 long LCD inverter boards to the lelf and to the right are dead.Those 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Nov 25, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
52inch Sharp Aquos has a constant blue blinking power on light no picture at all.Tried the resets,still the same,installed new inverter boards,still the same.Now what?
This problems is not those 2 long LCD inverter boards problems,why did u replaced those 2 long LCD inverter boards?I fix this problems before for a 46" LCD Sharp Aquos L46D55U tv.This problems,it the Tuner signal board is dead.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 08, 2010 | Sharp LC52D65U 52 in. LCD TV
Bravia kdl-40s4100 has no sound, no picture. Checked the line fuse to the HV power supply and it checked good. PS problem? Where can I find a replacement circuit board or would I be better off replacing...
The 2 long boards call the LCD inverter boards are dead.These 2 long LCD inverter boards are dead,must be replaced.These 2 long LCD inverter boards help the LCD screen to have a backlight to have a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jul 14, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
I have a lc-d45u sharp lcd that i get sound but no picture.
Ur LCD backlight inverter board is dead.Replaced this board will get picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD backlight inverter board,it a long board shape.
Mar 02, 2010 | Sharp Aquos LC-19D45U 19 in. LCD TV
The TV just don't turn on
Check ur power source like A/C cord connection.If ur power light & stand by light blink.Ur power ic inverter board is dead.
Aug 25, 2009 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
Sharp LC-26d4u tv won't turn on/power light is off
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Aug 17, 2009 | Sharp LC-26D4U 26 in. LCD Television
Televison & Video Logo
20 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
