Question about Cell Phones
How do I play my music on the H D card ? - Cell Phones
How to show my music folder in laptop which is in sandisk 2GB memory card ?
Your music folder should be under your user folder. If you have music on your SD card, plug it into the computer and open "Computer". The laptop should detect the card and give it a drive letter. Open it and play the music directly from the card or copy it to your "My Music" folder and play from any media program. If this doesn't answer your question please elaborate on the issue.
Dec 29, 2012 | SanDisk 2GB microSD Memory Card
Music does not play on my CECT i9
Try Refresh List or check in your Music Settings if the Memory Card is selected or not.
Jun 06, 2009 | Dual Electronics CECT P168 Cellular Phone
I dont know how to put music in the sd card
To add music to your DSi, first you need a spare sd card, and a pc or laptop that can sync with the card. Remember that the DSi only plays AAC type songs, so convert the songs you want to copy-paste on the card. This can be done easily on Itunes on which I use by right-clicking on the song and it will show you there ' convernt to AAC'. After saving the songs , take out the card from the pc or laptop and you can now insert the card in your DSi and play music and enjoy.
May 30, 2009 | Nintendo DSi Matte Blue Console
Skullcandy double agent headphones won't play music
Try to check the SD card, switch the protector, then try to play it again by pressing play button 3sec (the indicator will turn into blue), then the music will play.
Apr 19, 2009 | Audio Players & Recorders
LG Voyager, Music won't play.
Play music files - LG enV: At the main screen, press OK to select Menu. Select Get It Now, then press OK. Select Music & Tones, then press OK. Select My Music, then press OK. Select Songs, then press OK. Select the desired song, then press OK to select Play.
Aug 13, 2017 | LG VOYAGER VX10000 Cellular Phone
Creative zen music will not play on memory card
I also use Napster. Unfortunately with the music being on the memory card and not on the device itself, Napster detects this and will not play music from the memory card.
There are two things you can do to resolve this, the first one won't cost you anything. Move non-Napster music files to the memory card, leaving only Napster music on the device itself. As a Napster-To-Go device, you'll be able to play and sync without issues. The second is to purchase the tracks from Napster that you want on the memory card. Once you do this, you can play them in any compatible media - not just the Zen device.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Samsung E250 Music from SDCARD
vampey666 hello,
Check that the format is WAV or MP3 like it's supposed to.
Also, check that the files are loaded to the correct library on the card - Music or MP3.
Oct 29, 2008 | Cell Phones
Putting music on cell phone
This menu needs to be supported by mini SD Card.
It plays the music stored in the mini SD Card.
Copy the downloaded music from PC to mini SD Card,
and play the music stored in the mini SD Card through
your mobile phone.
Store music in the mp3 folder on the SD card.
1. Press [MENU] .
2. Scroll through the downloaded music to display the
music you want.
3. Select the music you want to play then press
[PLAY] or press [MENU]. Then select “Setting”,
press [OK], then 1.All Repeat, 2.Repeat,
Press [OK].
  • “mini SD Card” is connected to your phone, press
[MENU] to select 1. Setting, 2. Erase (Erase This/
Erase All), 3. Information.
Mar 30, 2008 | Audiovox CDM-8940 Cellular Phone
Saving music on my micro sd..
The only way the music can be played on a cell phone is if it is in mp3 format. you also have to list the songs individually (they cannot be separated into folders). to listen to the music you should have some sort of music player on the phone that will play the songs.
Nov 24, 2007 | HP iPAQ H1910 Pocket PC
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
