Question about GE Freezers
Have an older about 20+ years old ge upright freezer had to clean stopped freezing is there a reset switch for it
    Top Expert:
  • GE Master
  • 12,962 Answers
Make sure the electricity is connected. Check the start capacitor - check for the compressor running.
Posted on Dec 15, 2016
OLDER G&e UPRIGHT FREEZER PLUGGED IN RUNNING BUT
replace the ptc overload/relay on the compressor and it will cool again
Sep 11, 2011 | GE Freezers
I have a frost free upright ge freezer that quit working. No cold at all. It is less that 2 years old. Where did the quality go in GE? I have a GE microwave and it broke within the first year. Is it me or...
when the compressor is working and dont produce cold maybe the tube is leaking, causing the freon gas to scape. you need to reprocess your freezer to clean up and to find leaking tube to fix it. you nee a white line technician to fix your problem.
Jun 16, 2010 | GE 203 cu. ft. General Electric Upright...
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
Mar 01, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Freezer gets cold but doesn't freeze
check tem.p inside cabinet and let us know what you find
Jun 29, 2009 | GE Freezers
Problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Feb 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My ge upright freezer dosnt freez im almost sure it needs freon and i am certified im just not sure what type of freon it takes can you help
it should be notated on the compressor on the door and maybe inside the fridge. if my memory serves me correctly i think the clean air act states that it should contain r22. if nothing else you can call GE's support line and they can answer that question.
Good luck
Jan 14, 2009 | GE 13.7 cu. ft. General Electric Upright...
Neff 3.8 cu ft freezer.
if it works on superfreeze then the stat is faulty. all that supoerfreeze does is to bypass the stat. easy job
Sep 10, 2008 | Neff 3.80 cu. ft. / 108 liter Upright...
GE upright freezer
If this is a frost free model the fan could be bad. If not frost free it is probably low on freon. I don't recomment fixing this as you can never really trust the freezer again. Most of the time the leak can't be found and adding freon is only a temp solution.
Jun 24, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
96 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
