Question about Vacuums
My dc-40 retracting hose has no suction but hose is clear
  • Vacuums Master
  • 3,282 Answers
Dear Teresa,
Between the hose and the motor are several channels the air must flow.
These will plug up with dirt, lint, and hair.
Someone (you?) must take this machine all apart and clean it out. You will most likely find it has a wad of dirt in the tubing system inside the machine..
God bless your efforts.
Posted on Dec 15, 2016
Dyson 41 lost suction
Hi, it's Allie from Crucial Vacuum!
There are a few potential solutions you should try. Start by checking your unit's brushroll and clear it of any tangled hair strands or debris that my be blocking the airway. Follow by checking the internal hose for any blockages.
If the unit's suction is still not normal, the problem could be related to your filter. Filters should be washed frequently after every 1 or 2 uses or at least once a month, and replaced every 3 to 6 months for optimal performance.
You can purchase direct your replacement filter and belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=DC41&order=relevance&dir=desc
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 14, 2014 | Dyson Dc 41 Ball
Riccar 8995 no suction in hose
drop a quater thru hose make sure it goes thru
May 18, 2014 | Riccar Vacuums
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
Dyson dc40 no suction when removing hose
Check out my video on YouTube nclogging your Dyson DC 40
Or go to you tube Dyson DC 40 won't suck from the floor part
https://youtu.be/ZoPr-gh86no
Feb 03, 2014 | Dyson Vacuums
Loss of suction in hose
your hose is blocked get some thing long and thin push it done the hose and try and clear it
Dec 17, 2013 | Dyson DC40 Multi floor Upright Vacuum...
Vacuum shoots dirt or whatever it has just vacuumed out the back of the vacuum. I checked and cleaned the filter and the vacuum bag and it still leaves dirt behind the vacuum.
Good morning,
If you've checked both the bag and the filter, the next step would to check for any clogs.
I will detail what you will need to do below, or you can always reference your Owner's Guide (check: How to Check and Clear Hose Blockages)
http://www.eureka.com/service/manuals/77418_r2.pdf
Step 1: Remove hose from hose retainer on the base and check suction at end of hose - if little or no suction, check dust cup. Empty if needed. If no improvement, proceed to step 2.
(Make sure you turn off the switch and unplug the unit before proceeding to step 2)
Step 2: Remove electrical cord from cord hooks. Disconnect the clear tube by unscrewing the 2 screws, then lift away from cleaner. Check for any obstructions that may be in the tube or hose. Any obstructions can be removed by using a blunt instrument to clear the tube or hose (I will sometimes you a bent hanger or a retractable pointer). Flexing the hose may help loosen the blockage. After clearing blockage, reverse above steps to reassemble unitpcfloy86_0.jpg.
I hope this helps. If so, please give this solution a thumbs up!
Have a good day
~PCF
Mar 05, 2011 | Eureka Power Plus 4703D Bagless Upright...
Dyson DC 17 No suction
You might want to see if your cyclone is clogged. Clean it per the instructions on this site. http://www.exonotes.com/content/node/4
Jul 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Dyson dc 18 slim extender wand has NO suction. There is a plastic white cylinder object blocking.
If the floor head has suction and the wand does not, or vice-versa, the white cylinder you are referring to diverts the suction between the floor head and wand. If the flimsy plastic switch used to turn the cylinder is broken, you may need a new under carriage or just set the cylinder to wand or floor manually and use it as a one dimension cleaner. Depending on your ability, perhaps the switch can be purchases and replaced by a DIYer, but the job looks moderately difficult.
Jan 31, 2010 | Dyson DC18 Allergy Bagless Upright Vacuum
A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 30, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
