Can I run a 75000 btu garage heater with 1/2" gas pipe? The run is ruffly 50ft
    Top Expert:
  • Heating & Co... Master
  • 75,822 Answers
Call your local utility for this info, as this also depends on the gas line pressure not just the line diameter.
Posted on Dec 15, 2016
clyde2j2
  • 137 Answers
SOURCE: can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Posted on Feb 28, 2009
SOURCE: propane shuts off after releasing start button.
I have the same problem with my Reddy heater 55-f. Is it thermal coupling or relay?
Posted on Dec 08, 2009
SOURCE: Mr. Heater Natural Gas Garage Heater - 45,000 BTU.
my garage heater was working early this winter. I turned the thermostat to 0, but when I went to restart heater nothing happens, can you help me with this problem?
Posted on Dec 27, 2009
  • 58 Answers
SOURCE: fumes
WITH PROPANE THEY NEED CLEAN AIR, I HAVE THIS PROBLEM WHEN I USE THEM IN A CRAWL SPACE, TRY TO PUT IT SOME PLACE WHERE IT CAN GET CLEAN AIR, GOOD LUCK PLEASE LEAVE FEED BACK IF THIS WORKS
Posted on Jan 17, 2010
  • 117 Answers
SOURCE: I have a mr. heater big maxx. It is a 75000 btu
the vent pressure switch will have a rubber type hose off it to the combustion fan housing. pull the hose off and poke the conector with a paper cilp or wire to make sure it is not plugged at the housing. make sure the vent fan is running and jumper the switch if it comes on replace the switch if not look else where for your problem.a volt meter is a great tool . voltage across a switch means it is open and no voltage means its colsed. i should say to also check your venting as it maybe blocked. there is no reset
Posted on Feb 02, 2011
Maxx heater lights all burners for aprox 20 sec blower fan starts flame goes out flame lights again for 20 sec never blows much heat ?
sounds like its not getting gas fast enough to keep burning,that happen to me and the gas line was to long of a run for enough gas keep coming. so I up the pipe runs real good the flame keeps burning, so you know you can only go 25 ft in half inch pipe then u lose your flame
Oct 24, 2014 | Mr. Heater Natural Gas Garage Heater -...
How do you determine if a pool heater runs on Natural gas or propane
It should say on the tag inside the cabinet, or on the gas valve. Another indicator is that natural gas typically is fed through a 3/4" galvanized pipe, LP is often run through a 1/2" copper pipe. Be sure before trying to fire it up.
Jan 31, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a mr heater 75000 with a 4 flash blink code. the heater is brand new, only worked for 3 days. i have bypassed the 2 switches but still cant clear the 4 flash blink code.
According to the Owners/Installation Manual, the 4 flash blink code indicates that the High Limit or Roll Out Switch is open. This may be caused by a venting problem or high altitude operation. make sure you have the proper pressure to the heater's regulator. For Natural Gas it must be a continuous 7 water column inches.
For further information, I have included a link to your Owners Manual that you can download and print, for future reference. http://www.mrheater.com/upload/newsletter/MHU_HSU_CUH_60016_BL.pdf
Hope this helped to solve your problem.
Mar 22, 2011 | Mr. Heater Natural Gas Garage Heater -...
Mr heater 75000 btu thermostate turned up exhaust air turns on and ignitor doesnt ignite and times out
Probably your ignitor is bad...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 23, 2011 | Mr. Heater Natural Gas Garage Heater -...
I have a mr. heater big maxx. It is a 75000 btu natural gas. The preasure switch failed closed/open. How do I reset it? Or do I have to replace it?
Feb 01, 2011 | Mr. Heater Natural Gas Garage Heater -...
As soon as i hook up the thermostate it flashes the 3 flashes code and i have already tryed a new thermostate .... as soon as i unhook the thermostate it flashes for normal operation with no call for heat...
Try using it without the thermostat, tie the two thermostat wires together or put a jumper between
r and w. If furnace operates, you must have wrong style of thermostat
Jan 28, 2010 | Mr. Heater Natural Gas Garage Heater -...
Can i convert my dyna glo 75000 btu propane
Feb 28, 2009 | Heating & Cooling
Vent free wall heater starves for gas
The 3/4 pipe will provide enough gas provided that it does not have a lot of elbows in the run. The more elbows you have, the less gas you have at the end of the run.
I recommend that you call the company which provides you with the gas and have them come out and look at your problem. They will be able to analyze your situatioin and make a recommendation to you. This is a free service. Good luck with it.
Jan 22, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
