Question about Gateway Computers & Internet
I need to know what the original power supply was on a 840GM Media Center Computer
    Problem Solver:
  • 16 Answers
One of two Power supply setups came with the system
I need to know what the original power supply was - grn_arrow.gif103108 - 300 WATT HIPRO Power Supply
grn_arrow.gif103941 - 400-Watt Power Supply
They should like you back to gateway also
Posted on Jul 20, 2009
Required output voltages from an acoustic solution lcd television power supply unit
Only the original supply is going to work---schematics with voltages and wave forms are rarely available online except to a authorized service center for that brand---they want to SELL REPLACEMENT boards and not have someone fix them.
Jun 15, 2012 | Televison & Video
Power Supply for HP Media Center m1270 PC
Are you sure it's the power supply?
Most modern power supply units are of the ATX type. Brand should not matter. Your PC used a 300 watt power supply when new. You can purchase a power supply with more output (watts) if you like, but not less. You will have to purchase from a computer specialty store most likely - take the dead one in and compare it side by side with the new one before buying.
Dec 11, 2009 | HP Media Center m1270n (PP132AA#ABA) PC...
840GM will not start up all the way
Here is my flow chart.
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right?
First off, did you attempt to update BIOS before this happened. 90% of the time this is caused by a corrupt bios.
If you are the victim of a bad BIOS flash, don't freak there are some options. First off, if the computer (or motherboard) is still under warranty the Computer (or motherboard) can be sent to the Vendor for a BIOS reprogramming.
If you are a DIY PC builder and the warranty is expired you can take out the bios chip and sent it someone who reprograms BIOS chips or you can buy a brand new chip form them. I will show you my people.
http://myworld.ebay.com/***angelb***
or
http://stores.shop.ebay.com/Bios-Depot__W0QQ_armrsZ1
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen.
Jul 08, 2009 | Gateway 840GM (RB840GM) PC Desktop
What kind of external power supply does the media speaker needs?
Juster-Avia 3D-107 Media speakers.
I wanted to know what kind of external power supply it needed. I open the case and saw 4 diodes which tells me is a bridge rectifier circuit. I also looked at the filter cap and saw ????uF at 28 volts. Therefor, I did the Scientific Wild *** Guess( A.K.A. SWAG METHOD)
12 volts AC out at 1.6 amps or higher.
Apr 28, 2009 | Juster 3D-102 Computer Speakers
I have a gateway media center 610xl that has no power.
if you know on how to replace the power supply then do it, if not proceed to bring the computer. or if you have friends can do this, then much better.
Mar 15, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
What is the dc input for JBL Media 100
They run @ 12 volts 850mA. So an adapter with center pin positive at around 1A(1000mA) would give it enough "headroom". This means it would run cooler and last you longer. Amperage consumption is determined by the power it is producing, how loud you are playing the setup.
Mar 13, 2009 | JBL Media 100 Computer Speakers
Computer will not turn on. Power supply shows flashing green.
depending on the make of computer, a power supply cost's around $20.
Mar 12, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
Connecting power supply to peripheals
hi there,
U can get them from the internet try and go to the website related to your hardware, type in the model number in the search bar.
Please let me know hoe you get on.
Good luck
Philip
Dec 07, 2008 | HP Pavilion Media Center M1090n (PC100A)...
HP Media Center Computer
chk wether u r getting any lights on motherboard??
May 22, 2008 | HP Media Center m7250n (ED842AA) PC...
Computers & Internet Logo
104 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
