Question about Tablets & eReaders
MY /EWT935DK EMATIC TABLET
MY /EWT935DK THAT I GOT LAST MONTH ...THE SOUND WAS WORKING BUT NOW I ONLY HAVE SOUND WHEN IT IS PLUGED INTO MY HEAD PHONES.. THE ICON SHOW THAT IT IS OFF ...I CAN NOT TURN IT BACK ON
  • 183 Answers
SOURCE: I have an Asus Memo Pad HD 7 which I purchased 3
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Posted on Oct 30, 2013
Testimonial: "I did do a factory reset but the icon is still not showing and it still is slow at recharging. I didn't really have many programs anyway, a few simple card games, crossword puzzles and some weather apps. Right now, I think I have maybe 4 simple apps on the tablet and it is still not charging when on. I checked the battery status in settings and it says "not charging". However, if I turn it off and then plug it in, a red battery indicator shows it as charging."
  • 26 Answers
SOURCE: I WANT TO SEND MY TABLET BACK AND GET ONE THAT WORKS.IS THAT TO MUCH TO ASK???
go on the website of the company who made the tablet. go to the contacts page and send them an email.. or go to the company you bought it off and talk to them
Posted on Jun 05, 2014
  • 6702 Answers
SOURCE: i have an ematic tablet model:EGQ307 when i plug in the charger nothing happens when i try turning it on still nothing do you have any idea how to fix this?
Try to fine out what is defect the charger, the cable, or the tablet, by testing other cable, charger and tablet. not all 3 the same time, but one at the time.
Posted on Jul 13, 2014
  • 6702 Answers
SOURCE: Rca tablet modle rct6773w22 sound stopped working
Check the entry, where the headphone plug goes in, if nothing is in there. Just a speck of dust can disable the contacts, so the sound can't go to the internal speaker. If there is nothing wrong in the connector, try resetting the tablet and or restart the sound program you are using.
Posted on Jan 04, 2015
ving911
  • 6 Answers
SOURCE: I brought a ematic 7" Quad-Core tablet with Android 4.2 Jelly Bean. When I turned the tablet on and it go thru it cycle it show on the screen unfortunately, rstech_teni has stopped.
rstech_teni is in your tablet as a core system app even though it may be no such thing. I believe it was put there by the tablet
manufacturer in some contractual agreement with some advertising entity. The Lookout malware scanner may sometimes detect it as malware you should just ignore it and not try to delete it, as it will result in your problem again.
You will not be able restore the tablet from the hardware restore menu (hold power & up vol) because it will not allow you to answer "yes" to the prompt to proceed.
Two ways to fix, (Later, on how to actually select something)
1. (preferred)
Go to >Settings >Apps >All
scroll down to rstech_teni, select it, and then select "Clear data"
If you don't see retech_teni you may find "rs_9104_v30". This may be a clone of rstech_teni, do the same to it.
Your done.
2. (last resort, you will lose installed apps and data)
Go to >Settings >Backup & reset >Factory data reset,
Follow instructions, and your done.
And now the hard part, to deal with the message that will not let you navigate.
The easy way to get to "Settings" is to short tap power button to put tablet to display off/locked.
Then again short tap to turn on screen. You will see the rstecc_teni MSG hit OK in MSG. The MSG should be gone and not come back, do nothing else other than pull down the right upper drop down menu where the settings button is then select settings. At this point the evil MSG will come back.
From here on the frustration will start.
You will need to use two hands. Tap the rstech_teni OK with one finger on one hand and then quickly tap the Apps option with a finger on your other hand. This is kind of time consuming but it works after multiple attemps.
If you have a stylus pen, use it for the second tap to the option you want. It will seriously reduce the time it takes by making the second tap very accurate.
Within a half hour you should be able to get through this.
I know because I had the same problem.
Posted on Jan 26, 2015
I have a Google Ematic tablet model EWT935DK and it's stuck on the diagnose PC for 4 days it doesn't not have a pen spot for reset and I can't get into setting how can I fix my tablet. Pic attached
Try these steps:
  • Locate the reset button next to the headphone jack on the side of the tablet.
  • Insert a paperclip or another thin object into the hole.
  • Press the reset button with the paperclip to reset the tablet.
Feb 02, 2016 | Tablets & eReaders
EMATIC EWT935DK Touch Screen doesn't work.
sometimes the screen just glitches on any device that has touch screen if there is no reset pinhole on the device anywhere you may try to hold power and volume up until it restarts sometimes that can solve the problem I have to so this to my Galaxy S4 Active sometimes
Nov 04, 2015 | Tablets & eReaders
Return my ematic tablet it completely blacked out i demand a number to contact someone in person I have tried 10times now.
You do understand that you are not on the ematic site, correct?? So demanding here will do nothing.
First, if the unit is defective and you rcently purchased it, take it back to where you bought it and return it.
You also can fill in this form on the ematic site Support Android Tablets at an Economical Value Ematic and hopefully they will contact you to deal with the issue. Their email address is CustomerService@Ematic.us. and the support phone number is 1-888-968-1985 M-F, 9-5 Pacific time.
The last resort is that if you paid for the device with a credit card, call the card company and dispute the charge. You can explain that it is defective and they will not assist you with a repair or replacement.
Hope this helps.
Nov 18, 2014 | Tablets & eReaders
Can't reset ematic dual core tablet em63
A hard reset is a last resort, by doing a hard reset you will start all over (pending your skills) you will loose all aps/ data you may have had. Remember the basics on a soft reset you need to hold volume up button and then hold power on button it takes some time for the unit to boot, this is intentional.
Mar 22, 2014 | Ematic 4GB EM63 7" HD Dual-Core...
Where can i find drivers for my ematic tablet?
I assume you have the Ematic Pro Series tablet. The answer is that there is none. Since the Ematic Pro tablet runs a generic build of Android, Ematic cannot provide a driver. Sorry.
Nov 09, 2013 | Tablets & eReaders
Android tablet problems
Try going to system settings and select 'About Tablet' then checking you are fully charged and in good wifi signal select 'system updates' Update to any new version it finds.
Make sure it is fully charged with the screen brightness down (so it will last for hours, just in case). The last thing you want is a power down during an update...
Jun 05, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
