Question about Braun Health & Beauty
How can i get a braun scale filter type 3214, wk600?
    Top Expert:
  • Braun Master
  • 75,117 Answers
You will need to contact Braun for this.
Posted on Dec 15, 2016
How do I change my Braun ear thermometer back to F from C
You did not provide a model number however the Instruction Manuals for the various Braun Thermometers can be found here:
http://braun.kaz.com/kaz/service/prodResult/
Not sure if this procedure is common to all but this may work otherwise find the manual specific to your model number.
Changing the temperature scale
This thermometer is shipped with the Celsius temperature scale activated. If you wish to switch to Fahrenheit ( °F), proceed as follows:
Turn on the thermometer. ( If it is already turned on, make sure it is not in memory mode.)
Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
By pressing the activation button again, the Fahrenheit scale is activated, «°F» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
Release the /mem button to return to the ready symbol . The temperature stored in memory will automatically be converted to the selected scale when displayed on the LCD.
Apr 24, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
Need to change the farenheit
Here is a link to the manual:
http://braun.kaz.com/files/IRT3020GB,%20F,%20E%20%28USA,%20CDN,%20MEX%29.pdf
Or just follow these steps:
• Turn on the thermometer.
(If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and
• By pressing the activation button again, the Celsius scale is
activated, «°C» is displayed on the LCD. Each further pressing
• Release the /mem button to return to the ready symbol .
All temperatures stored in memory will automatically be converted
Mar 16, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Can you change the temp reading from F to Celcius on a Braun Thermoscan 6014?
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
Feb 28, 2011 | Braun Health & Beauty
My tea kettle leaks from the bottom
I just took ours apart for the same reason. In our case, it turns out that one of the two water indicators was cracked (at the top), causing the leak. The cracks were invisible without taking it apart.
There's a bigger leak near the bottom of the same piece, where a piece of the plastic is missing:
On the upside, the wk600 is really well designed - easy to take apart for repair. But I can't find replacement parts anywhere...
Feb 25, 2011 | Braun WK600 Cordless Electric Kettle
Need to convert C to F
Changing the temperature scale Your Braun ThermoScan is shipped with the Fahrenheit (°F) temperature scale activated. If you whish to switch to Celsius (°C) and/or back from Celsius to Fahrenheit, proceed as follows: (1) Make sure the thermometer is turned off. (2) Press and hold down the Start button (IRT 4020) or the «I/O» button (IRT 4520). After about 3 seconds the display will show this sequence: «°F» / «SET» / «°C» / «SET» ... (3) Release the Start button / «I/O» button when the desired temperature scale is shown. There will be a short beep to confirm the new setting, then the thermometer is turned off automatically.
Feb 16, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How fo I change the degrees from C to F degree ?
Feb 10, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Have a braun thermoscan and want to change it from F to C degrees lost manual
From the manual of the thermometer:
This thermometer is shipped with the Fahrenheit temperature scale activated. If you wish to switch to Celsius (°C), proceed as follows:
• Turn on the thermometer. (If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
• By pressing the activation button again, the Celsius scale is activated, «°C» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
If this isn't the right manual, go to: http://braun.kaz.com/kaz/service and select your country from there.
May 16, 2010 | Health & Beauty
My Braun Si 3120 Optistyle Iron is leaking water from steam holes
Scale buildup is unseating the rubber seal. Disassemble the iron. (Water filler hole part pulls directly forwards and can be pushed out from behind with a screwdriver.) Otherwise it's fairly straightforward. Clean scale off baseplate. Seal with silcone gasket before reassembly.
Jan 10, 2009 | Irons
Red light flickers, goes off, no heat
I had a similar failure with my Braun WK600. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettleful's; so far so good!
Oh, and if you take your kettle apart and your house burns down it is not my fault.
Nov 22, 2007 | Braun WK600 Cordless Electric Kettle
Health & Beauty Logo
67 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
Robin Hill
Robin Hill
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
