Question about GE Refrigerators
How do I replace a water thank on a GE refrigerator model GFSL6KKYCLS?
5 Suggested Answers
  • 86 Answers
SOURCE: my GE Refrigerator leeks water underneath when it
There is a pan under the the refrigerator that is to catch the water and let it evaporate from the heat from the compressor. The pan may have a hole in it or the little hose is not draining the water into the pan. This should be an easy fix.
Best of luck I hope this helps you:)
Posted on Apr 20, 2010
Testimonial: "sounds reasonable and will have to try this out! thanks for the advice!"
  • 272 Answers
SOURCE: i have to replace water
Greetings,
you can purchase the whole assembly part # WR17X12468 this is everything related to the tank. or, you can buy just the tank part# WR17X12390 this is about 50.00 less I'm guessing than the complete assembly...if this has been helpful, please let us know...Bruce Denton Master Appliance Technician
Posted on Dec 28, 2010
  • 1196 Answers
SOURCE: Ge refrigerator model #tpx24pbbgww is
Several factors could be involved in case your ice maker is not making any ice at all. It might be caused due to a defect in the water supply line. It could be possible that the water valve isn't getting any water. Check the water line at the back of the freezer for any blockage. Look for the water shut-off valve placed behind the refrigerator or under the sink and turn it off. If it make no difference, replace the primary inlet valve.
Posted on Apr 02, 2011
Sea Breeze
  • 4655 Answers
SOURCE: Model gfsl6kkycls. ice maker not filling with water, no action when pressing test button on side of ice maker for 15 seconds. I have replaced the water valve but no change. water dispenser works
I believe that your ice maker is causing the problem
GE Refrigerator Ice Maker Assembly WR30X10131
Posted on Nov 21, 2016
I have a GE GSH22JFTA WW that will not dispense water. Does dispense ice, crushed and cube. Panel is not locked. What part do I need? Thanks!
in the back of the fridge there is a module with the solonoid on it to open and close for the water, and it usually get damaged because of hard water, it is about 15.00
Aug 29, 2014 | Refrigerators
Water dispenser not working
Then try replacing the dual water control valve. First look around the fresh food section door frame for the model number of your GE Monogram Here is a link to a service manual=> GE Monogram Serevice Manual PDF On page 15 of the service manual explains how to locate and change the water valve=> WR49X10043
I will be here should you have questions, Thanks Sea Breeze
Jan 25, 2013 | GE Monogram Side by Side Refrigerator
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water not dispensing
Most likely your water control valve on rear of refrigerator has failed. Do this pour tap water into the ice maker make sure it is on and let the water freeze. If the ice drops and does not refill then the water control valve is the problem. If ice maker does not cycle then it is the ice maker. Find your model number around the door frame and tell me which model GE you have and I will tell you the replacement parts. Let me know, Thanks, Sea Breeze
Nov 19, 2009 | GE Refrigerators
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old. I just replace new filter still not working
If the water stopped before you replaced the filter we have something to consider is that the water control valve on the rear of the back of your Profile and down where the water enters the refrigerator you will see two coils and a set of female plugs attaches to each coil. Most likely the coil for your water dispenser is defective and and the side for the ice has not failed. When telling you the correct model of your profile is needed to give you the replacement part number for your dual water control valve. In a few moments I will show you an example of the part that I am talking about, Thanks, Sea Breeze
Oct 12, 2009 | GE Profile Performance 25.2 cu. ft....
Need install instructions to replace water tank
there is no online instructions that i am aware of.
Jun 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator, leaking water filter
The area above my water filter in my refrigerator is leaking. I doesn't leak until we run the water in the front of the door or the icemaker runs.I have changed the filer and the problem persists. Is there a part above the filter that needs replaced? The model # is GE TFX26ZPDABB. Thanks.
May 19, 2008 | Refrigerators
Addition to no water at the door
Check out GE replacement program for failed motherboards, not sure yet if our models are included, but if they are, they will replace or reimburse for cost of MB. I will post my result when I have it. I'll be calling them Monday. Ther are multiple Ph numbers, so I wiill start with Customer Service #. Per other research, not all departments at GE have access to list of failed MB models.
Nov 29, 2006 | GE GSL25JFPBS Side by Side Refrigerator
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
