Question about LG Heating & Cooling
My lg split didn't turn off - LG Heating & Cooling
My LG 1.5 ton split ac shows F10 error can u pls suggest wht to be done
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. Air Bulance AC Cleaning Repair Services
May 06, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Lg optimus chic e720 does not turn on
Hello all,
Please Can you support me ? I have an LG optimus Chic LG E720 that didn't boot and didn't enter in emergency mode due to bad software update. Power cut during software update.
So I need to know JTAG Pinout or whish flashing Box can I use to repair it ?
May 03, 2012 | Cell Phones
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
When I turn my LG BD270 on, the disp;ay keeps scrolling "Hello" and the TV screen flashes an LG logo screen. What could the problem be?
Is your LG unit new, or have you had it some time? If the later, it could be capacitor failure, which can cause all kinds of issues. I had an LG DVD HDD recorder which had a similar problem, except the LG logo didn't flash on screen. Does your unit have a hard disk? The prblem with mine was that the machine would not boot. Eventually, even th date display went, and it would not start. Replacing a bank of capapcitors solved he problem. I didn't have the equipment, but a repair engineer did it for £25in less than an hour.
May 27, 2011 | LG BD270 Blu-Ray Player
LG Art Cool, 2 splits. Error code CH7
Multi Splits and Multi V = indoor unit is set to run in a different mode from the master indoor unit. Set ALL indoor units to cooling or ALL to heating to clear.
Splits = Compressor Over Current (CT2)
Jul 09, 2010 | LG Art Cool LA121CNP wall/window Air...
My lg laptop screen seems to be split in 2 almost. It only shows three quarters of the screen and at the bottom the screen starts again
Try to turn off the pc and remove the cables and battery on the laptop. Press and hold the power button for 5 seconds, then reinsert the battery and the cables on the pc. Turn on your laptop and check if the screen will finally splits sucessfully...
May 15, 2010 | Computers & Internet
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
Lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Jun 13, 2007 | LG LS240CE Split System Air Conditioner
Heating & Cooling Logo
21 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
