Question about Humidifiers
My humidifier runs for about 12 to 15 seconds and shuts off in that lenght of time too. Whats up with this? Have brand new filters in it.
2 Suggested Answers
  • 4736 Answers
SOURCE: What happens if the humidifier
The humidifier has a float valve in it much like a toilet tank does. If the water gets to low, the float valve should allow more water to enter the tank automatically. When it reaches the proper level, the float valve stops the water. The water line (either copper or plastic) coming into the humidifier should have a shutoff valve on it. Make sure that it is turned on.
Posted on Feb 02, 2011
I have an essick humidifier and it keeps flashing CF but it continues to run. What does the CF mean.
Check Filter Indicator The ability of any humidifier to efficiently supply humidity output relies heavily on the condition of the filter. As the filter loads with impurities it gradually loses its wicking capability. When this happens, moisture output is reduced and the humidifier has to work longer to satisfy the selected setting. This humidifier has a check filter reminder timed to appear after 720 hours of operation. When the Check Filter (CF) message is displayed, disconnect the power cord and check the condition of the filter. If a build-up of deposits or severe discoloration is evident replace the filter to restore maximum efficiency. The CF message is reset when the humidifier is plugged back in.
Dec 03, 2017 | Humidifiers
Leaking at base due to too high of pressure or defective evaporative filter?
Humidifer FAQ's - General Filters, Inc.
www.generalfilters.com/support/faqs/humidification.html
I already have a GeneralAire® 1042 Humidifier installed, but have a 4,000 square foot home. Should I ... Can't I simply clean my Vapor Pad instead of replacing it? Where do I find ... I am seeing a very slight water leak coming from the bottom of my steamhumidifier. What do I do ... Legacy 1137 = 21 GPD / Up to 3,000 Sq. Ft.
GeneralAire® Legacy 1042 and 1137 Humidifiers - YouTube
? 3:22
https://www.youtube.com/watch?v=IM6IXVcjEdU
Jun 27, 2013 - Uploaded by GeneralAire Inc
GeneralAire® Legacy 1042 and 1137 Humidifiers - How to change the vapor pad .... Evaporator Pad (aka filter) change on aGeneral Aire 1042 ...
[PDF]General Aire Humidifier Owners Manual - On Time Mall
Jan 16, 2016 | GeneralAire Legacy 1040 Humidifier...
We havehad this humidifier for 3 months ans have has problems with a foul odor coming from it. We have replaced the filter 3 times! Is this normal? The cost to keep replacing the filter is ridiculous. Any...
I have the same poblem with mine. I'm telling you it was the brand new filter...after about a day the odor would start. I washed the filter out with white vinegar, then a drop or two of Dawn in hot water, then rinsed in cool water. Worked fine so far. It's been about a week. good luck
Jan 14, 2011 | Vicks V3100 1.2 Gallon Humidifier
Water runs out back humidifier into plenum & onto floor
Hi John Your whole question did not show up (maybe you can re-post) . I can answer what part i understand though. If the humidifier was wired in right it will not send power to the humidifier until the furnace is on, and calling for heat. This stops the unit from working in the cooling mode in summer.Make sure your furnace filter is clean as well
Hope that helps
Mar 05, 2009 | General Filters 1042-LH Humidifier
Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
Feb 10, 2008 | Honeywell QuietCare HCM-630 Humidifier
Lots of water run-off from Aprilaire 760 Humidifier
HI would check the filter in side might need changing or cleaning clean out wter tray in side, it could be just a blocked filter , hope this helps
Jan 03, 2008 | Aprilaire 700 Humidifier
Honeywell HCM-525 owners/operation manual NEEDED PLEASE!
The filter should be located below the tank. the tank should lift off of the unit and there should be a rectangular cavity where the filter fits. You will most likely find the old filter dried up and filled with a white crust. That is salt and other minerals in the tap water that the filter catches.
Jan 01, 2008 | Honeywell HCM525 Humidifier
Humidifiers Logo
122 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
