Question about Vacuums
How to the vacuum cleaners filters I lost my owners manual.
It's making a screeching noise
SOURCE: majestic filter queen canister vacuum cleaner
It will work again if you press the reset button which is the little (really little) button right on the back of the part that suctions.
Posted on May 25, 2007
SOURCE: owner's Manual
Apparently there was a split in the company and many repair manuals are under the company Aerus.
Posted on Aug 28, 2007
  • 1673 Answers
SOURCE: My bissell vacuum cleaner has lost suction...
Sounds like either the hose or the inlet down by the brush roll is clogged.
Posted on Jan 09, 2008
SOURCE: I need an owners manual for the filter magic, watermatic V vacuum
l have a water matic v vacumn with the manual.terry in canada.
Posted on Feb 01, 2009
  • 143 Answers
SOURCE: Hello. My dyson dc04 keeps making a loud screeching noise.
remove base cover by 3 'screws' 1/2 turn anti clockwise and clean well remove fibres replace cover and re try.
Posted on Sep 14, 2009
My DC35 Animal is making an intermittent screeching noise. Can anyone help.
Have you tried calling the company? Or try the internet or utube may have an answer.
Sep 17, 2016 | Dyson DC35 Digitial Slim Animal Cordless...
Screeching noise from eureka bagless the boss 4d
replace beater bar belt, check and insure beater bare rotates freely with belt removed.
May 19, 2012 | Eureka 5849A Boss Bagless Upright Cyclonic...
Hi My bissell proheat 2x 9500 is making a loud noise when the brushes are moving. I replace both belts and cleaned the brushes. Can you think of anything else it could be.
Hello there,
Try using other brush attachments, as broken bearings in a brush attachment will cause noise. If these troubleshooting techniques do not work, you may need to service the engine.
Remove the filter and bag of the machine and make sure that they are not clogged or full of debris. Clean any filters according to the instructions for your model or replace the bag. Excessive debris will make the engine run noisily.
Inspect the hose of the vacuum and remove any large debris that may be clogging the inside of the tube. Large amounts of dust, as well as stones or other hard materials that bounce, may cause a loud noise in the engine.
Remove the housing that conceals the engine of your machine and inspect the fan for damage or clogging. Remove any dirt or debris that may hinder the movement of the fan. Inspect the fan for any damage such as bent or excessively sharp blades. Replace the fan blades as needed; contact your vacuum manufacturer if the fan is damaged. The replacement part will include instructions.
Tighten the fan with a ratchet if it is loose on the assembly. A loose fan will make a rattling sound as the motor revs.
Wipe dirt and dust from the frame of the engine. Large quantities of dirt or dust around the motor can cause it to overheat, which can cause vibration and loud noise.
Look for corrosion around the engine. If the engine is corroded, it must be replaced.
Grease the bearings of the engine if you hear a grinding noise from the vacuum. Greasing is often performed through ports in the engine, or by removing the bearings. However, the actual greasing method is model-specific. Consult your owner's manual or send the vacuum to a service professional for this service.
Inspect the inside of the vacuum cleaner for other worn parts or broken pieces. Worn or broken pieces can cause loud noises to occur. Remove the broken part and order new materials from the vacuum manufacturer or take the machine in for service.
Hope this information was helpful to you. All the best. Elect_Comp
Sep 05, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hi, my dc07 cleaner has developed a very high pitch screech its not a constant sound but intermittent and last for a second or two and is very unpleasent, its a loud cleaner anyway but this noise is so...
it sounds like the bearings in the motor are worn out. the only solution is to change the motor, or the entire hoover. motors are available from ebay for about £35 and it will then need to be fitted. unfortunately these bearings do wear out eventually. once they start to make screeching noises like this, there is not much life left in them, and they will get worse rapidly.
if you decide to change the motor yourself, please feel free to ask for more details on how to do it.
hope this helps
Aug 16, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction
Sucked up a sock?? No seriously.. it may be as simple as that or that an on board filter is clogged. Check your manual for all filters and Hepa/screens and others. Also, is the unit making any odd noises since the non -suction scenario? Whining or screeching sounds, where is the motor impeller/vac bearing or similar is damaged or a hose is kinked within hte unit itself.. <not normally unless the unit has been taken apart and placed back together and crushed the main return vac hose. .
Apr 30, 2010 | Dyson DC14 All floors Bagless Upright...
Owners manual for kenmore power-mate # 116
Greetings from GoVacuum,
I wasn't able to find the manual for the Kenmore model, however I did find the instruction manual for the corresponding Panasonic canister vacuum cleaner. Your particular Kenmore model is actually made by Panasonic for Sears, and then Sears puts the Kenmore name on the vacuum cleaner. They are identical internally, and have the same parts and components, besides the filter that is behind the bag. Sears makes Panasonic put a specially designed filter in the Kenmore's so that the customer has to go back and purchase that filter from Sears.
To download the instruction manual, please visit the link below;
Owners Manual For Sears Kenmore Power-Mate Model 116.3489890C
You can also find a parts schematic of the power head below if you need to purchase parts;
Parts Schematic For Sears Kenmore Power-Mate Model 116.6489890C
I hope that this information helps you. Please let us know if we can provide you any further service, or if you have any further questions we can answer. You may email me at chris (dot) jones (at)
If this helped you, please click the Helpful button below.
Chris Jones
Mar 18, 2010 | Kenmore Vacuums
Lost instructions on how to use my dirt devil platinum force carpet cleaner
Generic problem for all Vacuums
Posted by Brad63ford on July 29, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the owners manual is from Royal itself and to contact the Royal factory @ the phone # listed below and to give them the brand name and model # in order to get the correct owner’s manual for your particular vacuum cleaner. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 29, 2008 | Vacuums
Lost Manual
Try this URL:
Then click on "User Guide PDF". A pdf of the owner's manual will download.
Jul 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
