Question about Mtd Products Yard Machines 158CC Tiller
I need to remove a bent blade on a yard machines 42 inch deck.
Do i have to remove the bearing assembly from the deck to remove the blade? or do i have to remove left handed bolts? maybe im not applying enuff torque. any help would be great folks. thanks
  • 130 Answers
Its no left hands bolts.under mower take the center bolt out and on each side off it.
Posted on Jul 20, 2009
    President:
  • 1,273 Answers
To remove the blades from a tiller, all you need to do is pull the pins out of the blades at the shaft and remove the offending blade. If it is an inner blade, it too will have a pin. The pins have a head on one end, pass through the shaft, and a locking pin through the other end.
Regards, --W/D--
  • woobie dog
    woobie dog Jul 21, 2009
    Oops, I came back and find that the heading was for a tiller, and you are needing info on a mower....
    FR23467 (above) is right. The only thing that I would add here is that the bolts come off much easier with an impact gun. Make sure that you keep your body parts out of the swing path of the blade. Safer still to lock the blade down.
    Regards again, --W/D--
Knocking sound in deck assembly of driving mower when driving without blades being engaged
sounds like bearing is broken if so replace this is dangerouse
to operate
Dec 10, 2013 | Yard Machines Garden
My 42 inch Toro seems to be cutting unevenly. The blades seem to be on correctly and I hope I haven't hit something to set the angle wrong
First thing to check is that the deck is level by the adjustments on wheels. Then check the bearings in the spindle housings and there is no play in the shaft when you try to move blade up and down. You then can measure from the blade tip bottom of deck on both sides (3 o'clock and 9 o'clock, and then 12 o'clock and 6'o clock They should all be the same. If not then either the shaft is bent, or the deck is bent slightly causing the blade not being parallel to the deck. If you have someone rotate the shaft you should be able to tell if the shaft is bent or not. If the deck is bent, then you will have to straighten it out till the spindle shaft is perpendicular to deck.
Oct 14, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
Left side blade cuts about an inch lower than right side , the left 21" when cutting is about an inch lower than the right 21", looks terrible, checked tire pressure and that was not the problem
measure the height of cut from the ground to the bottom of the deck all the way around, if it is the same the blade or bearing housing is at fault, if it is lower on the left look for a bent or broken mount from the deck to the tractor on that side.
Jun 14, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Blade hit the ground and bent. Now getting a growling sound from blade bearing housings and mower stalls after five minutes or so.I did replace the blades...
I have a feeling that the bearings were damaged when they hit. The new blades are ok, but the bearings are growling and I don't know what is causing the engine to shut off. I would pull the deck off, check out the bearings, replace them if needed, just wobble the blade back and forth, it shouldn't move, should be tight, Take off the belt and spin the blade by hand, and see if it growls. It could be the drive pulley bearings that went, check them out too. hope this helps.
Apr 27, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed My mower is a 42 cut and leave a row in the middle of the cut
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Sep 30, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Left side of deck to low 42 inch deck
check for bent blade bad bearings in housing or a loose blade or a bent mower deck
Jul 19, 2009 | Garden
One blade on deck gives an uneven cut
Sounds like a bent shaft, or the mounting is not flush.
Jul 04, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Mtd Products  Yard Machines  158CC Tiller Logo
656 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
